Quick question for you 4dr EF owners with power locks
Old Dec 23, 2010 | 09:59 PM
Tyson's Avatar
Default Quick question for you 4dr EF owners with power locks
from outside of the driver side, can you use your key to UNLOCK all the doors by holding the key in the unlock position?
yes or no.
thanks.
Old Dec 23, 2010 | 10:11 PM
alex14's Avatar
Default Re: Quick question for you 4dr EF owners with power locks
Mine just unlocks the drivers door.
Old Dec 23, 2010 | 10:12 PM
Tyson's Avatar
huh, ok.
what happens when you LOCK the door? from outside or inside manually (not pressing the switch, but the popsicle lever)
Old Dec 23, 2010 | 10:29 PM
4dred6's Avatar
what do u mean
Old Dec 24, 2010 | 12:29 AM
BiG ChOr!Zo's Avatar
no
Old Dec 24, 2010 | 10:30 AM
Nickster's Avatar
Originally Posted by 4dred6
what do u mean
He's trying to ask if ALL the doors lock when the drivers side is locked in any other way besides hitting the electric switch.
Old Dec 24, 2010 | 11:49 AM
Clipsed's Avatar
If you press down on the lock (not the switch) the doors will lock, but they will not unlock.
Old Dec 24, 2010 | 02:52 PM
Tyson's Avatar
Thanks guys. That's the answer I needed, but didn't want to hear. Looks like my door lock install is working as it should then. Too bad, unlocking the passenger door from the driver side was one of the abilities I was hoping for.
Thanks again. Jagoffs in integra forum were useless.
Old Dec 24, 2010 | 03:32 PM
Clipsed's Avatar
Im sure if you use a central lock mechanism from a newer model you can get the option you are looking for if you aren't wanting an aftermarket solution.
Old Dec 24, 2010 | 03:44 PM
dr_latino999's Avatar
My power door locks have worked once in 8 years, I hate them with a passion for their indifference to my anger.
Old Dec 24, 2010 | 04:20 PM
Tyson's Avatar
Clipsed I was contemplating that. Actually taking it from a toyota, my friends 94 corolla has the feature! Wtf Honda? Anyway, I don't think its so easy since the door locks may not have a sensor for unlocking, just locking. And honestly I don't want to unlock it all the time, just when I want to.
Plus its kinda annoying now that the passenger side ALWAYS locks when I lock the driver side. I can see myself locking the passenger in if I'm too quick to open and lock my door. So its kinda pointless now that I think about it to have even installed the driver side power door lock, when all I ever wanted was to be able to lock/unlock from the driver side, so I don't have to remind my passengers every time we get out. I could have done this with just installing the passenger power door lock and a switch. Wouldn't even need the control box. Hmmmmmm...
Old Dec 24, 2010 | 04:29 PM
Tyson's Avatar
On second thought, no I need the control box just to switch the polarity to the passenger door lock, but really that's it. Well whatever...
Old Dec 24, 2010 | 05:54 PM
Clipsed's Avatar
Actually I understand how you feel I too dislike it but deal with it for now as its not top priority on my list. Iirc the 2000ish accord I think has the feature to unlock just the driver and on the second key turn the rest of the passengers doors. I honestly think it will be better to just use an aftermarket set up and locate the main module to be in the cabin.
The way honda set up these locks is ancient technology I couldn't even set up my alarm which has a programmed ability to unlock the drivers door first and passengers second without a bit of ingenius wiring whereas the aftermarket systems have these features built right in.
If you want some more info or looking into an aftermarket setup lmk and ill see what I can find and recomend you.
Old Dec 24, 2010 | 06:03 PM
Tyson's Avatar
yeah no, at this point i got what i needed, a switch on the driver side. im going to depin the driver door lock so it doesnt lock the passenger side. its more than redundant when i have a switch already. id go and rip it out, but im too lazy for that. depinning is much easier.
im really not interested in an aftermarket setup, especially not now. but i agree, the realization that im working with 20 year old stuff has pretty much set in.
thanks again tho. it all makes sense now.
Old Dec 24, 2010 | 06:23 PM
Tyson's Avatar
wait, on third thought, the power window switch i used for the door lock switch might already have the controls to switch polarity inside of it... fugh... knowing me im not going to rest until i figure out the simplest solution and determine if its possible or not...
yeah... if i wired power and ground to it, it would reverse the polarity the same way the control box would for just 1 door. i used only 3 of the 5 wires to that switch and basically used it only as a rocker switch. but it also is the polarity gateway for the window motor. sigh. well now i know.
if anyone wants to simply add a power door lock to the passenger side, i can do a write up. lol.
btw, im talking about how i used this switch. i installed it the same exact way on the driver side, except only used 3 of the 5 wires. im certain now i could have just accomplished what i wanted with just the 2 components and clever wiring.
this is my power window thread.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/installed-power-window-passenger-side-my-crx-2868096/
new5gen
Honda CR-V & Element
Mar 22, 2017 06:50 AM
MIBPreacher
Honda Civic (2001 - 2005)
Feb 3, 2013 04:38 PM
wakaranai
Feb 13, 2009 01:50 AM
stevek89
Apr 25, 2006 04:44 PM
Civichatch972
Dec 31, 2002 10:27 PM
