B16a intake manifolds
Old Dec 23, 2010 | 01:17 PM
PHEDROTTO's Avatar
Default B16a intake manifolds
skunk2
type-R
blox
How works every one?? is not much difference between skunk2 and blox?? or should i go with type-R?
let me know if someone have one of second hand for sale
thnkxxx for your comments and info.
Old Dec 23, 2010 | 02:25 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: B16a intake manifolds
On a B16, a type R is a waste.
The other brands make no more power than an oem 2nd gen P30 B16A manifold
Old Dec 23, 2010 | 04:39 PM
crx_si-r's Avatar
I felt the difference on my lsv. I went with fist gen skunk2 (copy of type r manifold) with an oem p73 throttle body. But I didn't feel the difference until I hit closer to 5000 rpm. I like it and that's what I would suggest. I was running a stock obd0 b16a manifold before.
Old Dec 23, 2010 | 04:41 PM
dk=gsr's Avatar
they don't do anything unless you get bigger injectors and a tune, but for the gsr it helps up high end alot and has little to no low end if your still using the p72 ecu that still reads the dual runners.
Old Dec 23, 2010 | 06:05 PM
JeffBro's Avatar
Yeah I have been running the skunk2 manifold for serveral years now on my gsr and you notice a difference for sure. I am just running a b16 TB and it works well with that and a CAI. The bottom end was about the same and the mid fell off just a tad bit but the top end was way better. Overall its a good mod. Just be sure to reroute the cooling lines from the tb and use a plastic spacer between the head and manifold to keep the temps down.
1BstdEf9
Mar 22, 2005 04:21 PM
respectblades
Jun 22, 2003 06:15 PM
Drag-On
10
Oct 11, 2002 05:51 PM
88crxdx
May 20, 2002 12:20 PM
