skunk2 tuner 3 or pro 3 with my set up.
i have b20 86 mm with ls crankshaft,eagle rods and 14:1 compression pistons.head is port/polished and now cant decide which cams to use.i have used tuner 3 before and im pretty happy with the result.but i need to know more about the pro 3`s.
PRO!!! u hace alot of compression!!!
i dont have a flow sheet on my ported head but im going to use tri-y 2.5 collector headers and jg edelbrock intake with 70mm TB.
Why would you choke that motor with that header? AT LEAST make it the "big tube" tri-y and have a custom megafone w/ 3" collector made for it. Otherwise your just stepping backwards.
You have the displacement and compression to take full advantage of the pro 3 cams. If you use the header you mentioned it will hurt you a great deal. You should be running a custom header ideally but at least a big tube if you insist on using a copy.
i have a hytech side exit that i can use im just trying not to go with the side exit.i guess i have to go with the big tube.
The pro series cams should NEVER be installed without checking v2v clearances at the minimum. If you don't do that, you'll be playing Russian roulette dialing them in on the dyno.
A friend of mine has used both cams on his built motor and found that the Tuner 3's made the same power in vtec but less in midrange. The car ran a faster time at the strip with the tuner 3's also...both were degreed in too.
can headers like Bisimoto's V2 or SSR 4-1 Street Sweeper do the job well?...
I think either one would ask for the engine spec before they decide on the size n design of the headers so perhaps that way the header they'll produce is one that really match the needs...or as close as possible to the requirement...that should be OK, rite?....
Yes, that's how it normally works and what makes it a custom header.
hybrid_vtec
44
Apr 5, 2005 09:42 PM
FastAllmotorLsVtec
17
Jul 22, 2004 11:54 AM
