Spark plugs recommended for higher compression
Old Sep 23, 2002 | 12:44 PM
sneakychaos's Avatar
Default Spark plugs recommended for higher compression
What spark plugs (heat range) would you recommend for higher compression? Stock heat range fine, or should I be adjusting? ~12:1 compression
Old Sep 23, 2002 | 01:13 PM
Hooch'n's Avatar
Default Re: Spark plugs recommended for higher compression (trooth)
Bousch!?
I've heard good things about stock, but not sure with that kind of compression...mmm
Old Sep 23, 2002 | 03:38 PM
Default Re: Spark plugs recommended for higher compression (Hooch at 8400-RPM)
Old Sep 23, 2002 | 03:48 PM
sgT's Avatar
sgT
NGK 7s
Old Sep 23, 2002 | 03:49 PM
Default Re: Spark plugs recommended for higher compression (sgT)
NGK 7s
..thanks.
Old Sep 23, 2002 | 04:29 PM
Shark Tank's Avatar
get the platinum ngk 7's if you can afford them. they worked better and lasted a lot longer compared to the copper ones for me
Old Sep 24, 2002 | 07:22 AM
Mns's Avatar
Mns
Brisk Premium
Old Sep 24, 2002 | 07:29 AM
acura_typer's Avatar
Banned
I have been recommended Bosch part# 4227.
Old Sep 24, 2002 | 10:08 AM
Hooch'n's Avatar
Default Re: Spark plugs recommended for higher compression (acura_typer)
word.
Old Nov 8, 2008 | 11:09 AM
sabremike21's Avatar
personally dont like bosch, I would stick completely with ngk..
Old Nov 8, 2008 | 12:10 PM
neof69's Avatar
Default Re: (sabremike21)
6 yrs old...........
Old Nov 8, 2008 | 12:45 PM
BlueIntegraBoy's Avatar
I'm sure the OP has bought new spark plugs 6 times over already.
Old Nov 8, 2008 | 04:44 PM
EFsSuck's Avatar
Default Re: (BlueIntegraBoy)
<~BKR7ES and they might be gapped down, but ill bet they are still .031"
i will most likely be swapping to BKR7EIX plugs towards the end of my next dyno session though. those are Iridium plugs and are good for like, ever lol
i will NEVER run Bosch plugs.
Old Nov 8, 2008 | 04:47 PM
sackdz's Avatar
Default Re: (EFsSuck)
Why do you all Bosch plugs?
janiscrulzz
12
Jan 10, 2012 12:14 AM
h22nate
Apr 20, 2010 05:57 PM
em1si
Sep 3, 2007 12:23 PM
Westrock2000
Jan 26, 2003 09:58 AM
