Clifford AG4 Install on a teg-----------PLEASE HELP-----------Door Trigger Wire
10 Gray Door trigger (+ or -)
What do I connect this to? I cant seem to find that light green wire...gonna go look more... please help... I want to put my car back together...
[Modified by integra-modder, 4:07 PM 9/23/2002]
Its located in the drivers side door sil, thats where i tapped mine into.
[Modified by GsrSdn, 4:34 PM 9/23/2002]
your going to have to grab the lt. green/red stripe wire from the pass. side door trigger. (If you grab it from the drivers side; it wont read the pass. door
Pass. door trigger grabs all the doors including the drivers. BTW, the wire should be at the kick panel or above the fuse box; but if you didnt find it by now, itll be easier at the pass. door trigger.
) Pass. door trigger grabs all the doors including the drivers. BTW, the wire should be at the kick panel or above the fuse box; but if you didnt find it by now, itll be easier at the pass. door trigger.
I just said **** it, and put a diode on the door ajar light on the dash so that should do the same as hitting up the lt grren/red wire.
