Engine websites??
Old Dec 22, 2010 | 11:53 AM
eazy64's Avatar
Default Engine websites??
okay so i pretty much destroyed my last motor. its a D16a6 and am looking for something to straight drop in another d16 perhaps that just straight drops in less other modifications what would be the best????
and am also looking for webistes where they sell honda engines for cheap??
Thanksss!!!!
Old Dec 22, 2010 | 11:55 AM
KINGVEM^^ED6's Avatar
Default Re: Engine websites??
hmotorsonline.com
best bet
Old Dec 23, 2010 | 01:34 AM
BiG ChOr!Zo's Avatar
^^homomotors is definitely not cheap and the customer service is horrible if your after a d-series (zc sohc) for 88-91 civic/crx...been there, done that.
to the op visit www.cncmotors.com or try engine trend in vernon,ca or soshin trade corp in south gate,ca...i have gotten motors from all three of these companies and you cant beat a 6 month warranty.
Old Dec 23, 2010 | 08:38 AM
white90crxhf's Avatar
I guess i had good luck with them, they were about the same price as anyone else. (i could find that is)
to the OP you might be able to fix your motor cheaper than buying a used one. whats wrong with it?
Old Dec 23, 2010 | 11:47 AM
jdm ef8 89's Avatar
I'll sell you a motor. Its a JDM DOHC ZC 1.6 with only 60k on it. Straight drop in for a d16a6. I want to run it but cant cuz im in cali. I'll give it to you on the cheap.
Old Dec 23, 2010 | 02:22 PM
eazy64's Avatar
my valve got stuck the piston went up and smacked the valve and made a huge hole right through the piston and the valve broke and got stuck in the piston.
Old Dec 23, 2010 | 05:08 PM
bnerweener's Avatar
I got mine from Soshin, I think the ZC has gone up in price to $550.
Old Dec 23, 2010 | 05:23 PM
bnerweener's Avatar
now where were you when I needed you?! I got a ZC JDM engine from Soshin about 2 yrs ago, now all of a sudden I'm getting hassled about my smog check. I'm a little confused about some things related to my engine, you sound like you might be able to help ... mind if I pick your brain a bit???
Old Dec 23, 2010 | 05:45 PM
eazy64's Avatar
can u pass smog with the zc engines or is that honda big hassle.
Old Dec 23, 2010 | 06:01 PM
bnerweener's Avatar
i dont know! The guys who put in my engine said I shouldn't have any problems. In fact I passed smog 2 yrs ago right after putting the engine in. Had no problems at all. Now I'm due again and I went to the same Smog Check place and they told me that I have to go to the Referee Station and get a label to put in my door jamb that verifies everything is ok under the hood. So I went to the Ref Station and they are telling me that my ECU is not a valid part #?? As far as I know it's the original one, in any event it's the same one that was on it last smog check when it passed, so I am furious!!!
Old Dec 23, 2010 | 06:06 PM
ef8-dc2619's Avatar
i bet if you google jdm engines, you will get a bunch of hits
Old Dec 23, 2010 | 06:16 PM
bnerweener's Avatar
maybe someone out there can tell me - do i need to use a different ECU? (current one is 37820-PM6-L070)
Old Dec 23, 2010 | 06:18 PM
jdm ef8 89's Avatar
It matters what zc engine you have I know for sure you can pass with a sohc non-vtec zc but not a dohc zc and I'm not sure about a sohc vtec zc in cali.
And the pm6 should be the right ecu for a sohc zc because its a direct replacement for a d16a6 so I dont see why you would use another ecu unless there's a jdm version of the pm6.
Old Dec 23, 2010 | 06:25 PM
bnerweener's Avatar
i believe its non-vtec and sohc. it replaced a D16a6 in my 89 Civic Si.
if u had a dpfi motor and went mpfi u wont pass
Old Dec 23, 2010 | 06:27 PM
bnerweener's Avatar
i did not make any changes to wiring, etc. just dropped it in and connected to what was originally in my car
Old Dec 23, 2010 | 06:30 PM
bnerweener's Avatar
ok, dumb question then-how do I tell what kind of ZC it is? I didnt know there was more than one.
Old Dec 23, 2010 | 06:43 PM
bnerweener's Avatar
it's the "L070" in the ECU that the Ref is questioning. Says he cannot find any proof that it matches my engine configuration.
Old Dec 23, 2010 | 07:31 PM
que? explain this philosophy?
to everyone else yes you can smog both a zc sohc and a zc dohc motor at any smog check place...now here is where it gets ugly.
you can legally have a zc sohc as a replacement motor in any 88-91 civic/crx but you cannot have a zc dohc since it was never offered in the states...if a smog place gives you a hard time with the zc dohc then just take your business elsewhere.
now if you are dpfi with a d15b1/d15b2 and want to legally go mpfi the easy way, just use a zc sohc replacement longblock and use a d16a6 complete intake manifold with sensors and a pm6 ecu and you are good to go.
Old Dec 24, 2010 | 05:15 PM
eazy64's Avatar
so you can pass smog with a SOHC zc engine but not the DOHC right???
and that should just be a straight drop in? just drop it and connect everything do i need a different ECU and stuff or anything else i should know about before i drop get it??
Old Dec 24, 2010 | 05:35 PM
eazy64's Avatar
also my D16a6 Transmission should just be a direct bolt on the the ZC engine right????
Old Dec 24, 2010 | 09:41 PM
mike firme L.A's Avatar
i wana find me a good price for a zc dohc swap for my ef si but idk were ived already had a b16a2 and a b18c1 i dnt wana deal with the dohc no more i wana take power out of a zc dohc.. or should i just boost my d16a6 fully rebuilt dynoed..??
Old Dec 25, 2010 | 09:13 AM
dr_latino999's Avatar
I destroyed my A6 that way in 2005, valve randomly smacked into a piston and murder she wrote.
Old Dec 25, 2010 | 05:22 PM
Brendon12's Avatar
go on google and look up JDM engines, search the first 5 pages for all the sites you need
Old Dec 25, 2010 | 09:31 PM
eazy64's Avatar
okay ill give that a try tooo thankssss but if anyone knows that would be faster too
