Clifford AG4 install on integra??? HELP, quick please!
I believe you are referring to the INPUT of the DOMELIGHT Supervison and Door Trigger. In this case, it would be NEG. for the Integra. So this wire will go to GROUND. (Try to prep the harness and gather all your grounds together)
This will tell the alarm the doors are neg. trigger and that a ground will be supplied for the DOMELIGHT SUPERVISION feature. I like it when alarms are wired like this, because their are no repeative wiring. Example: one wire for door trigger and another wire for Dome light activation
I installed Cliffords years ago.
Thanks man
I dont think its the dome supervision signal, the door trigger should be the one that tells the system when the doors are open, right?
If it is the wire you specify then it would hook up to the door switch.
On the integra it is behind the driver rear panel, there is only one wire for the switch.
[Modified by nsxxtreme, 11:51 AM 9/26/2002]
Guys, I believe he is referring to the wire coming from the Clifford alarm, not the car.
Like I said before, Cliffords would have a INPUT wire for the door trigger and domelight supervision circuit. Either pos. or neg.
Then there's another wire that you wire into the vehicle's actual door trigger circuit.
See the difference???
Yep, Im sure. I just dont remember the wire colors of Cliffords today. I assume they are the same as before when I used to install them.
Here, try this:
The Clifford grey wire goes to the green/red of your Integra. That's the door circuit.
The Clifford brown with red stripe ( see if your model has one) goes to ground for a negative type door trigger. This is also the source for Domelight Supervision.
If I had your alarm with wires in front of me, I would be able to tell you.
Look at NSXXTREME or Kwhitlaw posts in the your other thread. One of them was referring to this circuit.
Here, try this:
If the wire comming from the brain of the clifford is the door trigger input wire, then connect it to the lt. green/red in the blue plug on top of the fusebox towards the right. This wire is the dome light wire and is what you should connect the door trigger input to.
Here, try this:
Here, try this:
The gray wire goes to the light green/red wire from the guage cluster with a diode, this is the wire that lights up the door ajar light.
The Brown/Red wire is grounded.
I know that when i was testing the system, If it was armed and I put the Gray wire to ground it would say door open, therefore I know the way I have it hooked up now is the correct way.
