14:1 comp. stock sleeves doable?
so do you guys think its possiable to have such hi comp on stock sleeves.
if so how do u dial in 14:1 compression to make it run right? ive always been a turbo guy now im looking into something else.
Stock sleeves is fine.. its not compression that effects a sleeve so much as , detenation, and what not..
What motor?? and why so much.. you'll need to clay, a dome that big is bound to provide head/valve clearence problems.
the reason that high is to just do it. i wanna do it in a h series.
how much does flat faced over sized valves increase compression on avg?
14:1 static compression is nothing...changing dynamic compression (i.e. big lobed cams, more overlap on cam gears, etc.) is what will matter in the stock open deck to ease the pressure on the stock sleeves and allow better running of the high octane fuel you use.
If its an h22a, try to get the older 94/95 blocks that came with closed deck...those can hold up really well...the newer ones came open deck.
good luck on doing that on stock sleeve H... they use FRM material and cannot use forged pistons... you must sleeve the block or you use iron sleeve replacements
I bet E85 would do it, you could really help your dynamic ratio a lot also by filling the cylinder with more fuel. When you get up to the compression your shooting for this becomes a much larger factor
It will really come down combustion chamber shaping and piston dome shaping, which would need to be matched incredibly well. makes this idea sort of difficult to pull off in a stock Hseries block
I ran 13+ daily with e85 on a 82mm bore stock gsr block with lots of dyno and track time. There is much more than just a compression # to factor in.
yea im going to build it correctly i just was wondering why nobody else does it. it just got me wondering and we wanted to build an NA engine. if were gonna build an NA engine, were gonna build an NA engine haha. i just wanted to check my sources.
Not many other people build it like that because most people have to use pump gas and don't have access to E85. That level of compression doesn't fit into many peoples build equations that arent using it for racing.
djangel1343
Nov 14, 2007 12:30 PM
Rev Red
18
Feb 13, 2006 11:37 PM
11sec CR-X
Sep 19, 2004 08:24 PM
importboi22
Oct 7, 2003 05:19 PM
