for those running brad penn oil...
Old Dec 22, 2010 | 09:10 AM
mike93eh2's Avatar
Icon2 for those running brad penn oil...
i just recently rebuilt my engine and was wondering when you would start running this oil in it. it says its partial synthetic.
Old Dec 22, 2010 | 09:29 AM
runsfromdacops's Avatar
Default Re: for those running brad penn oil...
i use BP brakein oil and simi synthetic in my motor. works graet.i did 500 miles on the brakein oil then switched be for i dynoed
Old Dec 22, 2010 | 09:53 AM
Mark Morris's Avatar
Brad Penn offers a break-in oil if you're interested. Best way to check if an engine has "broken in" is to do a leak-down test and see how well the rings are seated.
Old Dec 22, 2010 | 09:55 AM
locash's Avatar
We normally use the break in oil as well, but if its a race motor, I'm not sure I'd care too much. Hell, I never change the oil in the race car unless I have to drain it for some other reason, lol.
Old Dec 22, 2010 | 10:05 AM
mike93eh2's Avatar
well i just used some cheap oil for break in.. ive got about 100 miles of hard abuse on it. im changing oil now and wondering if i should put the brad penn in now or wait.
Old Dec 22, 2010 | 10:08 AM
tony1's Avatar
Put the BP in now.
Old Dec 22, 2010 | 10:13 AM
rookiepains's Avatar
Use it , its damn good oil .
I have 50 pallets coming in all grades.
Old Dec 22, 2010 | 10:17 AM
tuhboek's Avatar
Originally Posted by tony1
Put the BP in now.
X2
Old Dec 22, 2010 | 10:19 AM
twkdCD595's Avatar
I switched over after maybe a couple hundred miles, if that.
Old Dec 22, 2010 | 10:24 AM
boostedh22a's Avatar
Do you really need to use the break in oil, or can you just go straight to the regular BP?? I used 20w50 all last year with great results.
I'm starting with a fresh motor this coming season, which is why I'm asking.
Thanks
Old Dec 22, 2010 | 10:52 AM
MazworxRacing's Avatar
Use the break in oil newly built motor. Let it idle on it for a good 20-30 mins. Drain and replace with your engine builders recommendations on the oil.
Old Dec 22, 2010 | 03:00 PM
KStuned's Avatar
Break in oil until the tops of the pistons are dry. Usually 20ish miles on the dyno. Then Brad Penn of whatever weight you need. Seems to work great, we ran it all last year.
Old Dec 22, 2010 | 03:47 PM
4piston's Avatar
The zinc in the break in oil is the important part that is missing in modern conventional oils. Where we have seen a notable different is on camshaft wear. Don't just pour it in...take the valve cover off and really lube the **** out of the cam for before initial startup.
Old Dec 22, 2010 | 05:43 PM
mike93eh2's Avatar
yea the non-break in oil also has the increased amount of zinc. the reason i went with brad penn is due to the cam and cam journal wear from modern oils.
Old Dec 22, 2010 | 05:48 PM
tepid1's Avatar
Diesel oil typically also has a high level of zinc in it.... just a little FYI
Old Dec 22, 2010 | 05:58 PM
redboost10's Avatar
we have always used diesel oil for break in for all our motors on the engine dyno and chassis dyno. very good stuff for break in
Old Dec 22, 2010 | 06:04 PM
reaction360's Avatar
We don't have pallets of this stuff haha but like he said, its good stuff and we run em in all of our car's and customer cars.
Old Dec 22, 2010 | 06:38 PM
SPOOLINmatt's Avatar
hell i just use diesel oil all the time. lol.
Whats a break in period?
Old Dec 22, 2010 | 07:02 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
30min on the dyno lol
Old Dec 22, 2010 | 07:34 PM
lol my break in is from the time it cranks in the garage til the time its off when loaded on the trailer.
Old Dec 22, 2010 | 07:59 PM
kingaix's Avatar
I used non-synthetic valvoline and added the lucas brake in additive and broke it in on the dyno.No problems there...i also bought an oil filter magnet,its a good investment if your braking in.
Old Dec 23, 2010 | 02:04 AM
V-SPEC 1's Avatar
Good info.
Old Dec 23, 2010 | 03:28 AM
DRAGLS's Avatar
Another good option is Valvoline VR1 oils. They also
have a higher zinc(zddp) content. I have been using
it on the supra and teg since the engine rebuild.
Old Dec 23, 2010 | 03:42 AM
Originally Posted by reaction360
We don't have pallets of this stuff .
I don't have pallets coming , just wanted to feel like El Senor Parque.
The feeling is wack! Haha.
I own 5 bottles of the stuff.
Old Dec 23, 2010 | 04:10 AM
em_at_kfi's Avatar
I own a tube of their GP household oil.
I'll be running some tests with it on door hinges real soon.
