Oil restrictor ? with smoking on idle
Old Dec 22, 2010 | 08:57 AM
accord99power's Avatar
Default Oil restrictor ? with smoking on idle
I have good compression, vacuum, and no water in oil, spark plug tube are fine as well. However after idling for a min or two i start smokin oil out tailpipe. I thought i was a condition called "oil pumping".
However, after reading another thread abotu ebay turbos there was something in there about a OIL RESTRICTOR that doesnt cause smoking at idle. Is this true? also if i already have the problem will the OIL RESTRICTOR fix my problem?
Old Dec 22, 2010 | 09:22 AM
kyden's Avatar
Default Re: Oil restrictor ? with smoking on idle
do you have oil inside your charge pipes?
Old Dec 22, 2010 | 10:16 AM
from the turbo outlet there is eveidence yes but i have noticed it closer to the intake manifold.
Old Dec 22, 2010 | 10:37 AM
siblues's Avatar
intake manifold? or exhaust manifold?
Old Dec 22, 2010 | 10:47 AM
wow i need to learn to proof read i ment i *havent* have not noticed any evidence close to the intake manifold.
bigD
May 29, 2010 06:25 PM
94hondacivicvtec
Mar 21, 2007 11:49 PM
liquidxEG
Dec 8, 2004 07:27 AM
RaVAGE00
Jul 1, 2003 05:40 PM
ragejed
Mar 28, 2003 11:10 AM
