b series half shafts need help identifying these
Old Dec 22, 2010 | 01:07 AM
jessedm's Avatar
Default b series half shafts need help identifying these
i have these two half shafts wondering if i can use one of these one i do my gsr or b16 swap one is female and is stamped sk7 the other is male on both ends and is stamped sr3 both seem to have the same bolt pattern what did these come off of they didn't fit on my zc block one i was doing my zc swap so i kept hunting for others that i thought and was told where for a zc but ended up getting ripped off and now they sit
Old Dec 22, 2010 | 03:09 AM
richboi's Avatar
Default Re: b series half shafts need help identifying these
If its a B series, it will work, just so long as you have the CV Axle to pair it up with.
Old Dec 22, 2010 | 06:50 AM
jessedm's Avatar
ya ok i think i can figure out what kinda axels to get what was originally meant for the halfshaft right
Old Dec 22, 2010 | 06:57 AM
speedooo's Avatar
Originally Posted by g2nick@tuner-junction.com
For those of you who have been keeping up with my vibration problems, it is now FIXED! The problem was when I replaced my axles with 90-93 integra axles the half shaft that was on the car wasnt the correct one. I still do not know what axles go with that half shaft. My thanks really go to the guy I talked to at the Drive Shaft Shop. He told me that I have either a sk7 or sh3 halfshaft(intermediate shaft)and if I had the sh3 you need a shorteraxle. The sh3 is the odd ball one the sk7 is the most common. Ill admit I had my doubts but I bought a new half shaft and pulled the old one off the car and compared the two. As you can see in the pictures the one that was on my car was a sh3 and its about half an inch longer and would require a shorter axle. So when I put the regular length axle in it pushed in on the cv joint and caused it to bind and shake. Now its time to get it tuned. More to come.....
Old Dec 22, 2010 | 07:12 AM
jessedm's Avatar
ok so in an ef sedan with a b series motor swap and i use an sk7 half shaft with a b series cable transmission what axels do i use lol
Old Dec 22, 2010 | 07:16 AM
speedooo's Avatar
Seems like the sk7 halfshaft is shorter and can be used w/ generic da integra axles.
Old Dec 22, 2010 | 07:28 AM
jessedm's Avatar
just to clarify this is the shaft i have that's stamped SK7
and heirs the Axel i have that's stamped SR3
Old Dec 22, 2010 | 07:30 AM
jessedm's Avatar
so since the sk7 im most common i should probably use that then right what axles should i use to make a b series motor using this half shaft fit in to an 89 ef sedan
Old Dec 22, 2010 | 07:33 AM
speedooo's Avatar
Try google....I got these in about 8 seconds
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sk7-halfshaft-1230305/
http://www.tuner-junction.com/TJForu...aft-types.html
http://www.tamparacing.com/forums/t-...unity-com.html
Old Dec 22, 2010 | 07:39 AM
jessedm's Avatar
so 1990 integra Axel it is thanks for the help bro o wait what about the sleeved bolts needed i bought a pair that worked with my zc will they threat in to the b series block np hmm
Old Dec 22, 2010 | 07:44 AM
jessedm's Avatar
the sr3 shaft i have came with a good driver side Axel so could i get away with using the sr3 shaft and a passenger side and a 90 integra Axe on the passenger side? or will the sr3 shaft not even fit? lol
Old Dec 22, 2010 | 07:53 AM
speedooo's Avatar
sk7 and sh3 half shafts both bolt onto the back of a b series motor and fit inside a cable b series trans. you need the corresponding axle for each halfshaft, it appears that the sk7 halfshaft would be a better idea because generic da axles work with it and those are more readily available than whatever the sh3 uses. I believe the sh3 uses older prelude b20a1 axles.
Old Dec 22, 2010 | 07:59 AM
jessedm's Avatar
alright ill ditch that prelude shaft and order me some 90 integra axels just another thing to mark off my b series swap pre parts/checklist
Old Dec 22, 2010 | 08:02 AM
jessedm's Avatar
alright will i need to remove my dust ring thats in my hubs to make these work with out binding? or no?
Old Dec 22, 2010 | 05:17 PM
zrickety's Avatar
yes remove the dust rings, unless you have DA knuckles too
Old Dec 22, 2010 | 08:37 PM
jessedm's Avatar
ok sweet my axle questions are all answered lol thanks everybody for you help
flatblackfury91
Sep 12, 2012 05:40 AM
oneEg1Tc
Sep 20, 2009 10:58 PM
civicprojectPR
13
Feb 11, 2005 08:25 AM
91CRXpusher
Jul 26, 2003 09:16 AM
speedillusion
16
Jan 22, 2002 03:49 PM
