Removing brake MC
Old Dec 20, 2010 | 06:56 PM
Bruce Banner's Avatar
Default Removing brake MC
93 accord
I plan to remove my Brake MC to replace my proportion valve.
If that is not necessary, somebody please let me know.
I see 2 screws bolting the Brake MC to the brake booster, is that all?
After I do that, I am guessing fluid will flow out all over?
I am also assuming I will need to empty out the brake MC?
If I just top off and don't bleed, will I be able to stop?
I ask because I will be working on the car outside in 18F weather and I don't have the stuff necessary to bleed. I was just thinking of taking it to a brake place and letting them bleed it.
Apparently most shops around here don't like people bringing in parts for replacement, so I am opting to do it myself and save a bit of $. I can see the dam valve, the MBC is kinda in the way.
Old Dec 20, 2010 | 11:09 PM
chikin pickle's Avatar
Default Re: Removing brake MC
If you don't bleed the brakes, the brakes won't work, and you will crash the car on the way to the shop. You don't get a choice, you open the brakes, you bleed the brakes end of story.
As for the materials you need to bleed them, get some 3/8 clear tubing from the local parts place. You can use any container as the bleed container, old water bottles work great. Cap 'em off when you're done.
hteg12
Jul 18, 2013 05:13 PM
tommyofyork
Apr 8, 2007 05:45 PM
UltimX
21
Feb 8, 2006 08:29 PM
mikensu
May 26, 2005 08:30 AM
