Need help finding my relays
Old Dec 20, 2010 | 06:51 PM
Fresh Crx's Avatar
Default Need help finding my relays
I was wondering if anyone knows were I can find a book or if anyone knows were online there is a place shows you were all your relays are on a 90 Crx hf
Old Dec 20, 2010 | 07:04 PM
1990hondacrx's Avatar
Default Re: Need help finding my relays
what relays are you looking for ??? fuel pump relay, fan relay, condenser relay, turn signal relay? need more info on what your needing help with
Old Dec 20, 2010 | 07:28 PM
Fresh Crx's Avatar
It would have to be the fuel cuz my friend just did a b16 swap and we can here the fuel pump prime and everything but we jumped the starter after we primed it three times and it started man for a Little bit then shut off we no it's not geting enough fuel cuz we started it with starting fluid also so we wanna check the relays we are pretty sure it's that
Old Dec 20, 2010 | 07:44 PM
its next to the hood latch just look up there is a 10mm bolt holds it in there lil square thing cant miss it but if your fuel pump is priming its probably not that was car running before the swap? why are you jumping the starter check all your engine grounds make sure they are hooked make sure your ground to the wiring harness is hooked
Old Dec 20, 2010 | 08:41 PM
tonythetuner®'s Avatar
If u can hear the fuel pump prime its not a bad main relay. Check grounds I. No if the grounds on the thermastat. Are not connected ur car will not start...
Dxvid
May 2, 2019 02:05 PM
superbeastcrx
Jun 6, 2006 11:21 AM
si 1
Dec 21, 2005 11:03 AM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
