Throttle body, Intake
Hey Guys I was looking for some suggestions on what size and brand Tbody I should get?, and Intake too, No cold air, what brand sri??. 2001 Integra gsr, stock bottom end about 80k. B18c1, ported and polished p72 gsr head, +1 flat faced valves, Skunk2 valvetrain, springs, Ti retainers, stage2 cams and adjustable cam gears, Toda Tbelt.
no name Short ram, stock gsr Tbody, oem type r intake mani, walboro 255 fuel pump, aem rail, 450 dsm injectors, Rmf narrow header, 3" apexi n1 exhaust. exedy stage2 clutch, fidenza light weight flywheel. Avid mounts. p28 tuned on crome by Mikey @ Profunction. Im pretty happy with the car, Tuner told Me to get a better Tbody and bump up the compression to take better advantage of the cams. Any other suggestions would be appreciated! Thanks
So why do U say i dont have an oem Intake? Had a few people say the same thing till they have me pop the hood. Why is it that its not poss? Not a Blox, skunk2 or any of those, and been on the car since 2007.
Because bolt pattern on the ITR and B16 intake manifolds don't match the bolt pattern on the GS-R (P72) head.
keep your no name SRI. its a pipe its not going to be better because it says AEM on it. but instead buy a v-stack with that money and probably a bigger filter since i doubt the one you have would fit over it.
but i will say i really liked the weapon-r intakes when i used mine.
as for the TB if it'll work I'd say try maxbore otherwise omniman, skunk2 for the Tb.
i'd also worry about the people your showing your ITR mani to and after seeing it believe you.
Unless you re-drilled the flange to fit a p73 manifold on your p72 head (which I highly doubt the case is), you do not have a real ITR manifold. Check the bottom of the manifold under the FPR side of the plenum for a (p73) casting mark. You will not find one there considering its not an ITR manifold.
