Why do my tires go bad so FAst!!!!! =(
hey what suup guys. i have a 88'ef hatch. right now its pretty muuch stock suspension. besides the fact i have it lowerd on after market lowering springz in the front. an adjustable coilovers in the back. but ever since i lowerd the car my tires wear way to fast! what could be the problem!?
wow indeed...you need a wheel alignment up front and camber kits for the front and rear. your toe is def off from the lowering. it cannot be adjusted with the factory parts (not enough anyways). how do you lower the car and NOT know it will affect tire wear without proper adjustments?
the car is lowered...camber is negative..tire wear issue. the fact that theres coil overs in back and reg. lowering springs up front doesnt help either. id get a camber kit but guess not everybody has money for extra parts.
no, the wear is because of bad toe. not camber. negative camber is good.
i dont care to have another debate on this. its been proven many times.
xunkn0vvnx
Oct 5, 2005 10:16 AM
