Sensors & DAtalog....
Whats sensors do you guys log?
I Know these
Fuel Presure
Oil presure
Water Temp
IAT
Oil Temp
Turbo Back Presure
Egt
Boost
Anything Else ?
I Know these
Fuel Presure
Oil presure
Water Temp
IAT
Oil Temp
Turbo Back Presure
Egt
Boost
Anything Else ?
In addition to the OP's:
Front speed
Rear speed
Air pre IC
Air post IC
Water pre IC
Water post IC
Coolant pressure
Turbo inlet air temp
Turbo inlet air pressure
Lateral force
Suspension travel front and rear
Brake pressure front
Lambda
EGT x4
Front speed
Rear speed
Air pre IC
Air post IC
Water pre IC
Water post IC
Coolant pressure
Lateral force
Lambda
EGT x4
Good thing they give you an hour between rounds.
Alot of what he listed is not something you look at every round, it is nice to have. Data is everything. You can always have a lot of data, but when you do not have enough data, thats when you get into problems when you have something you can not figure out with limited data. If you have no data, you are just guessing a lot of time.
Hope that makes sense. Log as much as you can, that your system will allow. Just log what you think is important first.
As stated above, data is everything when you're trying to figure out issues. I plan on using every available port on the M400, then adding the 888 for everything i've forgotten, lol.
You can never have enough inputs. No matter how many you have you'll always find a way to use them all up.
I personally like using my ecu for all tuning related inputs and use a dash logger for everything else.
What's the best way to log rear speed? What is needed? Alway wanted to ask for more info on that subject but never have. I'm looking into loggging more things for 2011 so hoping to learn a lot
its simple u do passes & when data starts drifting from the norm u can finds things stating to arise before they become issues,
or find ways to fix issues ending in more power.. the list goes on...
the dyno is just the beginning stage of TUNING a car... the real tuning is done at the track with data.. then hours looking at the data post race reading & making changes on & off the track...
The set up I have is a hall effect sensor with cobalt magnets machined into place on the rear wheel.
