D16Z6 Running Rich... PLS HELP
ok, I have a stock D16Z6 engine into my 93 Del Sol si. And since I bought it my check engine light is ON with the code 41 (heated oxygen sensor heater). My stock ECU is P28, but what I have is P0A ECU for 94-95 Accord EX (F22B1 engine). I tried to find P28 but I can't find any here. I have replaced my O2 sensor many times and I do reset my ECU but still the code 41 is still ON. And I feel my car is running rich because my CO is high at idle, black smoke when I Rev over 5,000 RM and my gas mileage is around 25 m/g. Can anybody help me to fix this 41 code? I have tried to check the wiring of my o2 sensor to the ECU and i think everything is alright. Anybody can help? Thanks a lot
One word.....eBay
http://motors.shop.ebay.com/i.html?r...=p4506.c0.m282
Again still a little lost took under 30 seconds to find you over 224 listings granted some of them are for chips but there are at least 10 ECUs on the first half of the page. Mabe your only problem is that you are not in the US but I am sure that you could get it shipped
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Thanks guys. I'm living in UAE, hard to find P28 ecu here. Is it work the try to buy P28 ecu? maybe isn't the ecu that causing the problem. I have tried using P84 ECU also but no luck, still the code 41 appearing on my dash. Is there any ECU that is very close to P28 ECU? I mean one that I can use instead of P28 which can work with my o2 sensor without any problems. If there is any, I'll try to look around in here before buying P28 from ebay. I so sick from the code 41, I want to get rid of it. Thanks!
howangseg
10
Dec 29, 2005 12:29 AM
