Squeaking in the morning
Old Dec 16, 2010 | 08:52 PM
Gresini's Avatar
Default Squeaking in the morning
B18C Manual 95 EG9
Every morning when engine started squeaking appears for about 2mins only.
Sometimes during cold days it happens as well, but only for about a minute.
Pressure/pads/bearing replaced about 1.5yrs ago.
Can anyone help?
Old Dec 16, 2010 | 09:04 PM
aka red's Avatar
Default Re: Squeaking in the morning
it's your belts that are squeaking . have you have them replaced they may need to be adjusted or if not they may have cracks and will have to be replaced.
Old Dec 16, 2010 | 09:29 PM
Gresini's Avatar
Will go check asap. Thanks!
Old Dec 16, 2010 | 09:31 PM
aka red's Avatar
no problem . while you are at double check the pulley's and tensioners for rubber build up r adnormall wear it's only a small chance that theres a problem but don't want to miss it
Old Dec 17, 2010 | 12:06 PM
-__-'s Avatar
^^he's right. usually, the alternator belt is the culprit. start it up and see if u can pin point the belt
Old Dec 17, 2010 | 06:05 PM
Ghost Eg's Avatar
as they stated its either the pulleys or the belts are yu sure there is no motor oil on any of the belts or the pulleys?
integra15
Sep 13, 2008 01:34 PM
Bgesy
Apr 20, 2006 01:33 PM
Lamb
10
May 25, 2005 09:44 PM
xstalkrx
Oct 24, 2003 03:57 PM
MrEg
Oct 13, 2003 04:48 PM
