Aftermarket Cd player question....
Old Dec 16, 2010 | 02:55 PM
smartguysjt's Avatar
Default Aftermarket Cd player question....
I have a aftermarket pioneer headunit and i thought that when you put your key in the ignition on acc or crank your car the radio suppose to come on by itself not actually cutting the radio on manually....i also have to set my settings everytime i get in the car...i have the memory wire connected to the red (power)wire hooked together but this doesn't change anything...is there something im missing or anything you can give me info to help with this problem thank you
Old Dec 16, 2010 | 02:58 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Aftermarket Cd player question....
Wrong forum. Did you use an aftermarket harness or did you chop up the wires?
Old Dec 16, 2010 | 03:01 PM
roadsqueegy95's Avatar
there should be a power wire that just get power when you turn your key on, but the memory wire should be to a wire that has constant power, as to save your settings.
like grumblemarc said, you use a harness or cut your wires?
Old Dec 16, 2010 | 03:22 PM
ozh_hawaiian's Avatar
you gotta tap into the ACC wire, which I think is yellow, which gets the power when key is on, and the solid red wire should be constant power, but really you could tap into any wire that only gets power when the car is on
Old Dec 16, 2010 | 03:38 PM
The Grumpiest
Don't quote me but if you used a harness the yellow and red wires are backwards on it. If you cut you wires shame on you for not respecting your ride enough.
Old Dec 17, 2010 | 07:36 AM
Red_Army's Avatar
can always buy one from best buy...its color coded.
Old Dec 17, 2010 | 07:41 AM
itsnotfast's Avatar
You have it backwards. Yellow is constant power and red is ACC.
Old Dec 17, 2010 | 07:52 AM
V.MoMO's Avatar
when i put in my stereo i took notes and this is what i got(on my ek)
yellow/red = ignition(acc), red on aftermarket harness
red = ???, didnt connect to anything
black = ground, black on aftermarket
white/blue = battery(constant power), yellow on aftermarket
red/black = power antenna, blue on aftermarket
the rest are + and - terminals for the speakers
and while ur at it check ur fuses just in case u blow/blew one along the way
Old Dec 17, 2010 | 07:55 AM
itsnotfast's Avatar
You have a power antenna on your EK?
Old Dec 17, 2010 | 08:06 AM
V.MoMO's Avatar
haha NO but a professional shop had hooked up a radio to my old civic and thats how they had it
laelowimports
Mar 6, 2008 01:27 PM
JdM_RACeR07
Aug 29, 2006 10:11 PM
1 Cam Wonder
Audio / Security / Video
Dec 20, 2004 11:02 AM
tianporn
Jun 25, 2004 05:50 AM
TegDroP
Jul 3, 2003 07:17 AM
