Suspension & Brakes Theory, alignment, spring rates....
take a look drop on eibach sportlines
Old Dec 16, 2010 | 09:39 AM
jdmcivic2fast's Avatar
Default take a look drop on eibach sportlines
delete
Old Dec 16, 2010 | 11:55 AM
96hb's Avatar
Default Re: take a look drop on eibach sportlines
The Pro Kit offers less of a drop. Probably should have bought them.
Old Dec 16, 2010 | 12:21 PM
edited up top!
Old Dec 16, 2010 | 12:26 PM
delete
Old Dec 16, 2010 | 04:16 PM
1.5Slowmatic's Avatar
thats about what mine look like with the sportlines. they are for function and look. not hellgaydumpt like some people seem to like
Old Dec 16, 2010 | 10:27 PM
'00DC2's Avatar
yup that's what its supposed to look like. sportlines for civic's and integra's usually drop equal front and rear. so the result is usually front higher than rear. those springs are great for daily driving.
Old Dec 16, 2010 | 11:27 PM
98civdx's Avatar
Master Detailer
It is kind of hard for me to compare, but my friends car seemed to be a little lower then your car is. However without them both in front of me I cant be 100% sure.
But I have a question for you, what in the hell happend to that bumper?
Old Dec 17, 2010 | 08:29 AM
someone got hungry and took a bite of out it lol. nah his bumper was cut because he's had a drag motor in there with an side exit header.
Old Dec 17, 2010 | 08:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Did you loosen all suspension bolts, jack up the suspension on each corner to put a load on it, and then torque all bolts to spec with the suspension loaded? I'm betting no...
Do that and it may actually make the car sit a touch lower, and will also keep your bushing from tearing, assuming they're still rubber.
Old Dec 17, 2010 | 09:08 AM
ok which part of the suspensions do we loosen up? uca,lca,ect.ect?? and how much load will we know to put on it before tighten up the bolts ?
Old Dec 17, 2010 | 09:12 AM
Community Builder
Loosen ALL suspension bolts that pass through bushings that rotate/flex as the suspension moves up and down. This includes all UCA, LCA, and toe compensator arm bushing bolts.
Jack up the suspension on each corner until that corner just barely comes off the jack stand. This doesn't fully translate to ride height (it actually works better if you disconnect the sway bars) but it's close enough for gub'ment work. Then tighten all bolts on that corner to spec while the suspension is loaded.
This is the method to use if you can't get access to the bolts underneath the car while the car is actually sitting on its own wheels. Obviously a 4-post runway-type lift or alignment rack would be a better place to do it.
many styles
Nov 24, 2005 02:42 PM
swappedcx
29
Nov 16, 2005 06:30 PM
hondaracin24
Sep 29, 2004 10:05 AM
natrl
Mar 27, 2003 02:29 PM
Amuse9
Oct 26, 2002 07:18 PM
