Lighting HID/Xenon kits, Retrofits and Associated Topics
HID randomly turns off
Old Dec 15, 2010 | 08:52 PM
2000EJ8's Avatar
Default HID randomly turns off
i just installed a new sit of Bi-xenon HID lights into my civic and noticed the driver side headlight will randomly turn off. I've checked all the connections and grounds and everything seems to be fine..could this be anything else other than a cheap *** set of HID's?
Old Dec 16, 2010 | 03:58 PM
wtf_is_jdm's Avatar
Default Re: HID randomly turns off
Is it only when the car is off or when you are at idle or.... when you are driving? And is this a plug and play kit?
Old Dec 17, 2010 | 08:28 PM
2000EJ8's Avatar
itll happen while im driving, when im sitting at a stoplight, and when the ignition is off.....really its all just at any random time, and yea its a plug and play kit.
also the driver side will slightly flicker
Old Dec 17, 2010 | 08:37 PM
2000EJ8's Avatar
could a simple relay wired in place be a solution? i looked on a few websites and some people are saying they think thats the case
Old Dec 18, 2010 | 05:43 AM
wtf_is_jdm's Avatar
the reason i ask about plug and play is because for my set, i actually had to cut the oe plugs off and solder the ballast wires to the harness. i guess oe plugs are notorious for trapping gunk and debris inside by the contact points. another reason but unlikely is the fact the your ballasts may have an internal voltage regulater. meaning that if there is not enough juice to run both at once it will automatically run just one. but like i said, that is pretty unlikely in your case. hardwire the hid ballasts to your harness and you should be good to go. gl
Old Dec 18, 2010 | 03:05 PM
ShinsenTuner's Avatar
No Jodas
^ I've installed a lot of HID kits and have never ran into an issue with the OEM Harness plugs. If anything I would blame the kit itself for being defective. Cheap PnP kits are known to flicker and have bad connections.
Old Dec 18, 2010 | 08:19 PM
MONEY888's Avatar
hEY WUTS UP i SEE YOU HAVE ISSUES WITH hID KIT ......HAVE YOU CHECKED YOUR GROUND WIRES .
Old Dec 19, 2010 | 05:35 PM
Veeeeetek's Avatar
I have a set on my Tacoma and they flicker sometimes too :/ cant figure it out
Old Dec 19, 2010 | 06:52 PM
EatSleepJDM's Avatar
i bought a set for my 00 civic from passwordjdm which are plug and play and i have the same problem both of my lights do it, i have to turn the lights off then on again and they will stay on.
Bizzle5OH3
Lighting
May 15, 2011 06:55 PM
OnePointFive
Aug 7, 2007 09:23 PM
GQ 05YellowEVO8
Feb 9, 2002 07:19 AM
