HID randomly turns off
i just installed a new sit of Bi-xenon HID lights into my civic and noticed the driver side headlight will randomly turn off. I've checked all the connections and grounds and everything seems to be fine..could this be anything else other than a cheap *** set of HID's?
also the driver side will slightly flicker
the reason i ask about plug and play is because for my set, i actually had to cut the oe plugs off and solder the ballast wires to the harness. i guess oe plugs are notorious for trapping gunk and debris inside by the contact points. another reason but unlikely is the fact the your ballasts may have an internal voltage regulater. meaning that if there is not enough juice to run both at once it will automatically run just one. but like i said, that is pretty unlikely in your case. hardwire the hid ballasts to your harness and you should be good to go. gl
^ I've installed a lot of HID kits and have never ran into an issue with the OEM Harness plugs. If anything I would blame the kit itself for being defective. Cheap PnP kits are known to flicker and have bad connections.
hEY WUTS UP i SEE YOU HAVE ISSUES WITH hID KIT ......HAVE YOU CHECKED YOUR GROUND WIRES .
i bought a set for my 00 civic from passwordjdm which are plug and play and i have the same problem both of my lights do it, i have to turn the lights off then on again and they will stay on.
OnePointFive
Aug 7, 2007 09:23 PM
GQ 05YellowEVO8
Feb 9, 2002 07:19 AM
