major short killing battery, no start
Old Dec 15, 2010 | 07:49 PM
stickman78114's Avatar
Default major short killing battery, no start
ok, 1st battery dies. fast. headlights will kill the battery frm a charge in about 4min. w/ a new battery.
when i put charger to dead battery the dizzy starts to tick, the starter clicks, and ivac sensors buzzes( i can feel it on the ivac and hear it frm the end of the intake arm) w/ the key in the start position. the main relay also goes crazy w/ clicks, n my seat belt on the passenger side buzzes(where the belt recoiles into)
when i have the charger set to "start" the starter cranks weak and kills the battery.
also when the battery is charging and the key out of the ignition; when i turn the lights on clicking comes frm various places. and again kills battery quickly.
i have a good neg @ the batter, thermo, and head
the starter cable is tight
i dnt even kno what im sposed to search. srry i tried.
thnx
Old Dec 16, 2010 | 09:55 PM
Default Re: major short killing battery, no start
bump
Old Dec 17, 2010 | 01:47 AM
d0wnShiFt's Avatar
What car is this?.. alittle more specific would be great!
Old Dec 17, 2010 | 05:48 AM
1990hondacrx's Avatar
kinda crazy but have you had the alternator check i know a bad alternator can draw a battery to nothing in not time flat mine was actually drawing power from the car sitting over night and killing the battery.. just a thought cause it is hooked up to the battery threw the fuse box.. also the car never through a check engine or a alternator light and i had the alternator tested and it was bad
Old Dec 17, 2010 | 06:31 AM
it's a dohc zc in an 89 crx si. it started up and was driving fine, then it would wanna die when the rps dipped low. ima have the alternator checked out today and see what comes up
SiB16A
Jun 11, 2006 12:37 PM
LaOstha
17
Feb 21, 2005 02:15 PM
crawdad689
Sep 30, 2003 12:11 PM
insane_integra
Sep 3, 2003 09:17 AM
