Heavy brake shake after new brakes
I was having a mild shake while braking when I first purchased my car. Suspected warped rotors and decided to change all of my brakes.
After changing my brakes I now get a HEAVY shaking while braking from my front left. I've done a lot of brake changes in the past and this has stumped me.
I have also gone through 3 different calipers, thinking I got a faulty one.
I have also checked the bolts on the caliper to bracket, bracket to knuckle as well.
Pedal feels great, very low speed braking seems fine and ZERO shaking while driving at any speed.
Is it possible that my rotor isn't flat on the hub?
I'm usually not a guy to ask for help because all I do is search, so any thoughts or suggestions would be really appreciated.
Thanks
- New front calipers/rotors/pads and new rear drums/shoes/wheel cylinders. Also new master cylinder(bench bled)
Thanks
Your problem is that you need to rebuild your steering rack. You've got too much play. All that play is due to the "rack end bushing" look it up in the faq on how to replace. Its cheap but labor intensive.
But its the fix.
But its the fix.
Nontheless I'll get it done and update the thread.
Thanks for the help Tyson
Vagitarian
23
May 8, 2013 09:38 AM
adim
Jun 11, 2009 06:33 PM
