Help Reading These CEL Codes (see video)
Old Dec 14, 2010 | 09:40 AM
sk8board{Pete}'s Avatar
Default Help Reading These CEL Codes (see video)
Just trying to verify that my car is pulling codes 71 and 41..
Thank in advance
http://s67.photobucket.com/albums/h3...t=IMG_0574.mp4
Old Dec 14, 2010 | 10:17 AM
Former User's Avatar
Default Re: Help Reading These CEL Codes
You have three codes: 7, 10, and 41.
Old Dec 14, 2010 | 10:44 AM
thanks
Old Dec 14, 2010 | 10:50 AM
Default Re: Help Reading These CEL Codes (see video)
7 Throttle position sensor: So all i would have to do is change the TPS and get it calibrated..?
10 Intake air temperature sensor: there isnt a plug on my 97 civic ex harness for it
41 Heated oxygen sensor heater: what does this even mean (o_0)
Old Dec 14, 2010 | 10:54 AM
Give us some information about your car.
The CEL codes could indicate sensor, wire, or ECU problems. You know why code 10 is thrown, but some tests may be necessary to sort out the others.
Old Dec 14, 2010 | 11:05 AM
Its a 97 civic ex with an obd2 b18b1 swap running a obd1 ls ecu.. In july, before I moved, i changed the water pump, timing belt, rear and front seals, head gasket, oil pan gasket was changed as well as the head being completely re-done.
the o2 sensor is plugged up with an extension cable purchased from password jdm
Then the car started to idle real low, so I pulled off the Throttle body and IACV and cleaned them, the idle has improved but occasionally falls low then idle normal.
Also i changed the ignitor and coil in the dizzy, but the car wont idle normal if the dizzy isnt retarded..
Sorry for being all over the place
Old Dec 14, 2010 | 11:08 AM
Check whether 7.5A dash fuse 15 is blown and whether the TPS connector gets 5 reference volts from the ECU.
Are all three TPS wires properly pinned to the ECU? Same for the O2 sensor.
gerald.keel
Aug 18, 2013 10:41 AM
geneeunit
48
Aug 17, 2009 05:40 PM
Left_Sock
Jul 27, 2008 01:43 PM
killaj12
Mar 5, 2007 04:16 AM
SOHCex20
15
Oct 2, 2005 12:36 AM
