Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
how to switch 3rd brake light bulb? :p
Old Dec 13, 2010 | 04:34 PM
Calavera's Avatar
Default how to switch 3rd brake light bulb? :p
It's a '04 accord coupe and the 3rd brake light just went out. I looked under the trunk and the plug comes off but how do I get to the bulb? I tried twisting the socket but it wouldn't budge.
I also need to know what kind of bulb I need to buy so I can do this myself. Thanks in advance for the help.
Old Dec 13, 2010 | 04:47 PM
soon2bdropped's Avatar
Default Re: how to switch 3rd brake light bulb? :p
try twisting it with a needle nose plier.
Old Dec 13, 2010 | 04:48 PM
lazlong's Avatar
Socket should just twist out. Bulb type- #1: http://www.hondapartscheap.com/south...t=0&quantity=0
Third brake lights are mandated by the fed for new cars only. Check in your state and see if you even need it to pass inspection. We don't need it here in TX to pass.
Old Dec 13, 2010 | 06:26 PM
redbull-1's Avatar
Pull the bulb straight out. Like your avatar's proverb, "Empty your mind, be formless, shapeless — like water. Now you put water in a cup, it becomes the cup; You put water into a bottle it becomes the bottle; You put it in a teapot it becomes the teapot. Now water can flow or it can crash. Be water, my friend."
It's a 7440 bulb. If you ever need to look up a bulb, use this site:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old Dec 13, 2010 | 07:51 PM
fourtyounceslsh's Avatar
use your fingers.
Old Dec 29, 2010 | 03:32 PM
Calavera's Avatar
edit: it worked. :D
barfo
Feb 8, 2015 04:12 PM
SCinCA
Oct 6, 2014 06:35 PM
curtie94
Feb 7, 2011 01:53 PM
cyclonedr
Oct 7, 2009 01:47 PM
vinny76010
Apr 20, 2006 12:32 PM
