DPFI to MPFI ECU Help
Old Dec 13, 2010 | 10:18 AM
JesseRay's Avatar
Default DPFI to MPFI ECU Help
OK I have acquired a 1991 Honda civic Hatch.. previous owner swapped in a D16y5 with 5spd but left the dpfi. I have come across a mpfi manifold and im looking to do the swap but my question is what ecu will run this y5 properly as i know its a vtec-e motor and its origin is obd2 so original ecu is out of the question.. is there a alternate choice? i have googled this many hours with no real answer..
Old Dec 18, 2010 | 03:15 PM
tonythetuner®'s Avatar
Default Re: DPFI to MPFI ECU Help
A chipped p28 with jumper harness. And look up how to do dpfi to mpfi swap. A lot info on how to do the swap
Old Dec 18, 2010 | 03:27 PM
BrandonR's Avatar
I vote if your set on keeping OBD0, then PM6 or PM8 (HF). However, it would be best to swap the head to run the PM6. -Later, BR
Old Dec 18, 2010 | 03:37 PM
SilverEF88's Avatar
Check this out. Read it and then read it again. Helped me wire up my B18c5. Invaluable.
CLICK HERE
I would also do as tony said and go with the chipped P28. $175 and it will open up a lot of tuning capabilities.
Old Dec 18, 2010 | 03:47 PM
efjones9's Avatar
if u not to good at wiring i can help u out for cheap pm me
JDMhoe1992
Dec 23, 2011 05:22 PM
Tyla12
Nov 2, 2010 04:36 AM
EF_monster
Nov 23, 2008 06:44 PM
lrch26
Mar 29, 2007 05:19 PM
RACEPAK
Oct 7, 2006 12:25 AM
