hard start in cold
Old Dec 12, 2010 | 08:37 PM
79powerwagon's Avatar
Default hard start in cold
ive got a 90hf with d16z6 and now that the temp here in maine is under 30 degrees most of the time it dosent like to start very easy, i dont know much about these cars or fuel injection for that matter, if any one has any ideas that would be great.
Old Dec 12, 2010 | 08:52 PM
CRXREFIC's Avatar
Default Re: hard start in cold
ehh... cold will affect you no matter what...
it will have hard start no matter what.. because the oil gets really thick when its cold
Old Dec 12, 2010 | 08:58 PM
well i do know its not normal to have to crank for 10 minutes just for it to keep dying on me
Old Dec 12, 2010 | 09:20 PM
CRXREFIC's Avatar
um wat kind of oil is in it?
CRXREFIC's Avatar
condition of motor?
Old Dec 12, 2010 | 09:22 PM
5w30 castrol, other then not wanting to star when its cold its in good condition
Old Dec 12, 2010 | 09:28 PM
CRXREFIC's Avatar
so motor is in healthy shape as in no low compressions and any minor problems...
eh only time i have really cold start is when my car has been sitting for too dam long in the cold...
well as far as i know try starting the car every now and then let it warm up so it dont reach really low temperatures...
coolant is basically mix right for the temp right? if not water can freeze up... causing problems with water pump and such....
Old Dec 12, 2010 | 11:10 PM
miguey310's Avatar
has this just started happening ? bad starter ? also try synthetic oil , better for cold weather
Old Dec 13, 2010 | 12:37 AM
rd91sib18c5r's Avatar
You loose alot of cranking amps when it's cold.
Check your batt.
Old Dec 13, 2010 | 09:42 AM
brand new battery, it does it in the summer but not close to whats happening now, but i think i figured out the problem, i dont think the person i got the car from put the motor in with the conversion done to the wiring harness, i think i might have to get a new harness or somthing
Old Dec 13, 2010 | 10:22 AM
FSRslug's Avatar
Get a block/oil heater. Never had a problem with my truck not starting, but it will crank slower than normal in the cold. Its was -10F this morning. I had it plugged in for a few hours and it fired up like it was 70 degrees out.
You can get the kind that are magnet mount and just stick it on the oil pan. You can get one as low as $25. Not sure how effective they are though. Nicer ones are more expensive, but if you dont have the luxury of a warmer garage they are nice.
Old Dec 13, 2010 | 10:29 AM
FSRslug's Avatar
I misread your post. I thought you meant -30. +30F isn't cold and a block or oil heater isn't going to help.
Old Dec 13, 2010 | 11:15 AM
jdmef69's Avatar
coolant temp sensor. the two prong one under the distributor. take it out and clean it and if that dont work replace it. if the sensor is bad and it dont read that ur motor is cold then it wont dump the extra fuel to start a cold motor. happened to mine i only had to clean mine out but it worked after that no problem
Old Dec 13, 2010 | 12:10 PM
miguey310's Avatar
any codes ?
Old Dec 13, 2010 | 12:40 PM
crxrocks's Avatar
Does giving it a little gas while starting help?
Old Dec 14, 2010 | 08:27 PM
no codes and giving it a little extra gas dont work either, ill try the coolant temp sensor.
Old Dec 27, 2010 | 09:25 PM
got it figuer out the dumb *** that put the motor in decided that he didnt need the plug for the intake air temp sensor so he cut it off, now i get to go to the junk yard and try to find one.
kristi-accord
Apr 5, 2011 06:38 PM
mr2
Sep 22, 2010 09:24 AM
Tizzakowack
Dec 30, 2008 07:16 AM
bopbop93030
Apr 15, 2008 07:14 PM
Kan
Nov 30, 2004 01:51 PM
