Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV has no spark!!!!!
Old Dec 12, 2010 | 07:11 PM
kondrams's Avatar
Default CRV has no spark!!!!!
Help!! I have a 2001 CRV that will not start. I drove it to the location where it currently rests and it was running fine. I turned it off and about 1 hour later tried to crank it... No spark. I checked all fuses, relays, and even pulled the back-up radio fuse for 10 minutes, still no spark. From reading other threads it appeared that it may be the ignition control module. I bought a new module and installed it. Still no spark. The fuel pressure is seems to be strong so I know the fuel pump is not being cutoff. Does anyone know if the inertia switches could cause the loss of spark and still have proper fuel pump operation. I checked the resistances across primary and secondary coils and it appears to be within spec. Can anyone give me advice??
Old Dec 12, 2010 | 07:32 PM
bigballing222's Avatar
Default Re: CRV has no spark!!!!!
Check the ignition coil in the distributor, I think you can get it checked at any auto parts store
Old Dec 12, 2010 | 08:51 PM
slowesteg's Avatar
check dizzy,coil, cap, rotor, spark plug wires, spark plug
Old Dec 13, 2010 | 11:30 AM
saleensolution's Avatar
X2
Crossbreeder
Aug 16, 2010 05:52 AM
j4yzn
Aug 24, 2009 12:45 PM
DelSlowmo
61
Feb 12, 2009 07:50 PM
91crxracer
Aug 26, 2006 02:05 AM
GoldCoin
Aug 21, 2006 06:29 PM
