b18a1 swap into 97 civic - What axles?
Old Dec 12, 2010 | 12:38 PM
h22accord101's Avatar
Default b18a1 swap into 97 civic - What axles?
i am in process of finishing up my b18a1 swap in my 97 civic and i was wondering if i can use the da b series half shaft and axles
Old Dec 12, 2010 | 03:43 PM
Default Re: b18a1 in to a 97 honda civic
bump
Old Dec 12, 2010 | 04:36 PM
H22AFerio's Avatar
Your gonna need 94-01 axels and halfshaft If I remember correctly the DA driver side axle is shorter and the DA halfshaft doesnt work right with the hydro trans.
Old Dec 12, 2010 | 07:32 PM
Default Re: b18a1 swap into 97 civic - What axles?
sum da are hydro 91 thru 93 and thats what it came out of i did some research and it says the obd1 da the axles and half shaft will work only difference is the male and female ends are different than the dc on the driver side there backwards from the dc but thanks for your help man
Old Dec 12, 2010 | 07:49 PM
itsnotfast's Avatar
Correct, the DA axles will work you just need the corresponding half shaft.
Old Dec 13, 2010 | 10:43 AM
H22AFerio's Avatar
no prob man I wish i could of had some more info for you.
Old Dec 13, 2010 | 10:52 AM
94EG8's Avatar
Seagull Management
All DAs use a cable tranny. You can use the axles and intermediate shaft as a set though, but you will need the driver's side axle seal for a '90 - '93 Integra.
Old Dec 13, 2010 | 12:58 PM
BryanM.'s Avatar
Resident Gearhead
Yes they will work.
Works fine withe the hydro trans, my EH2 with an OBD1 B16A has DA axles (Raxles) and half shaft.
You just need to use a left side oil seal from a DA like 94EG8 said.
Old Dec 13, 2010 | 01:13 PM
H22AFerio's Avatar
I see, well thanks for the good info boys ya learn somthing new everyday.
Old Dec 13, 2010 | 08:18 PM
thanks guys i didnt know about the seal ima have to go pick one up.
jdmjackson
Feb 14, 2013 03:52 PM
aemintgsr
K Series
15
Sep 9, 2009 06:43 AM
EK_vzla
Nov 12, 2007 10:35 AM
jdm_vtec
Aug 30, 2007 11:57 AM
bipedbear
Apr 4, 2006 12:33 PM
