quick head gasket question
Old Dec 12, 2010 | 12:21 PM
yfz's Avatar
yfz
Default quick head gasket question
A while back I put dual valve springs in my gsr and now I am planning on putting the motor back to completely stock so when I pull the head to put the factory springs back in I plan to put replace the thin head gasket with an oem one. Will it be a good idea to buy new oem head bolts or will reusing them be fine?
Old Dec 12, 2010 | 01:11 PM
EHondaJDM's Avatar
Default Re: quick head gasket question
What do you plan on doing with the engine?
Old Dec 12, 2010 | 01:24 PM
fv8s's Avatar
I presonally would invest in a set of ARP's considering the head will be off, but the OEM ones will work just fine.
Old Dec 12, 2010 | 01:35 PM
yfz's Avatar
yfz
I plan to put the motor back to stock because I want to sell the parts to go towards my other project and the honda is my daily. So yes, I will need new head bolts?
Old Dec 12, 2010 | 02:32 PM
93egSLEEPER's Avatar
I would just reuse the ones you have UNLESS they have been taken off and torqued down a bunch of times. If they torque down they will be sufficient enough. No point for ARP studs unless its a High comp or boosted setup.
Old Dec 12, 2010 | 03:08 PM
EHondaJDM's Avatar
What he said ^
Old Dec 12, 2010 | 03:32 PM
NinJa_FLiP's Avatar
+1 for the oem head studs..
Old Dec 12, 2010 | 05:11 PM
yfz's Avatar
yfz
The head bolts that are in there now are the original ones and have been taken off and retorqued one time. This would be the second time if i reuse them. So I will just use them and save the $100. Thanks for all the replies
Old Dec 12, 2010 | 05:18 PM
yfz's Avatar
yfz
do you guys have any links that can show me the vaccum line routing for the stock intake manfiold of a jdm b18c(gsr)
Old Dec 12, 2010 | 07:13 PM
fv8s's Avatar
http://www.acuraautomotiveparts.org/...s=&view=normal
89 SI zero
10
Apr 19, 2013 03:01 PM
marshall12395
18
Apr 14, 2013 10:07 AM
DrkHrse
54
Feb 10, 2013 03:55 AM
1SlowSi
Jan 27, 2005 11:11 AM
bdicustoms
Aug 25, 2004 07:35 PM
