b16a1 to 91 crx si swap help
Well the engine and everything is in the car, it has now come down to wiring the b16 up in the crx. I've been researching the crap out of this an cannot for the life of me find a decent wiring diagram or even some good descriptive info on it. I just have a few questions.
What would be the preferred harness to use to wire up the b16a1 to the 91 crx si?
Does some one have a tutorial or some pictures on the wiring? and a wiring diagram?
Will post the ecu code up as soon as i get it.
From: I told you to wait in the truck in Texas, United States
All the answers you need should be within links in the FAQ at the
top of this forum so check that..
FAQ link: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
You want to use the engine harness that came with your car originally
and make a sub-harness using connectors
that hopefully came with the new engine.
see: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/b16-2nd-o2-sensor-900501/
JDM Panda
Jul 2, 2006 06:32 AM
wherethefocowe
May 25, 2005 06:23 PM
