NEED HELP!!! CAR CRANKS BUT DOESN'T START
ok so i got a 98 honda civic and i just finish swaping out the motor and hooked up all the plugs in the right places. well when i went to go start it up all it does is crank. the motor is getting fuel, spark, and the compression on the motor is good. so what can it be. someone please help me. thanks
well the firing order is right i checked it like three times and i installed the timing belt before installing the motor in the car. but i'm going to check the timing belt again just to make sure it on right. what else can it be?
btw what engine is it?
make sure the connector at the distributor is plugged in completely, its the connector for the cam, crank, and tdc sensor, without any of these would trigger a no start
its a obd2a model civic with a d16y8 motor so the plugs are hard to get mixed up
Joe Leoffler
Honda Civic (2001 - 2005)
Jun 25, 2019 02:55 PM
