Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
engine blew will lx engine fit help
Old Dec 11, 2010 | 08:31 PM
mannydhanju's Avatar
Default engine blew will lx engine fit help
hey fellow members. I have 2008 ex and my engine blew today ... but I was wondering will a 2008 lx engine work for my ex. The lx came out of a automatic if that matter any. Any support would be much appreciated.
Thanks Manny
Old Dec 11, 2010 | 08:38 PM
RICO_'s Avatar
NO MERCY!
Default Re: engine blew will lx engine fit help
I'm sure it would. The engines are the same. It's just mainly creature features that are different.
Exactly how did you manage to blow your engine anyway?
Old Dec 11, 2010 | 09:22 PM
so the big questions lies how the engine blew... well lemme tell you its simply bad luck. I changed the oil on the civic about a month ago and my sister drove it to where she lives about 140 miles from me and drove it for a month no problem and today she called me in panic saying these lights came on and the engine was making noise... lights would be check engine and oil light. I asked her to check the oil dipstick and she said there was no oil on the stick and she she hadn't see any spots in her driveway or anything so i was trying to figure and explain where to check to see if it was leaking . Finally she called her friend considering I am about 2 1/2 hours away this late at night and he happened to discover that there was no oil plug. WOW!!! Explain that how that civic could run dry for however long it did and then all of a sudden a light that is supposed to come on during warning time (oil light) and not during disaster time. Is this a possible default in the system? Just my family's luck.
Old Dec 12, 2010 | 09:33 AM
RICO_'s Avatar
NO MERCY!
Well oil drain plugs just don't fall out. Either it wasn't tightened properly, or your sister hit something to bottom out the car and possibly knock the plug loose or crack the pan around the plug to where it fell out. These plugs only require 29 ft/lbs. of torque to be tightened properly so its pretty easy to get it tight enough....but also pretty easy to OVER-tighten it and begin stripping the threads.
Whatever happened happened very close to the check engine light and oil light coming on....because once the oil drains completely from the engine, the car isn't going to make it very far at all without dying. Certainly not a month. She'll be lucky to have made it up one city block with no oil.
Old Dec 12, 2010 | 11:07 AM
bee guz's Avatar
You had better check to see if they are any differences in the block between the auto and the stick, other than the obvious stuff,like the shape of the rear of the block where the bell housing bolts up.
Old Dec 17, 2010 | 03:36 PM
Stripped Honda's Avatar
99-0104
please tell me your kidding with this statement..
change the flywheel and use your intake and exhuast manifold and you will be fine.. the block is the same from a auto to a manual ...
Old Dec 17, 2010 | 03:44 PM
SIvic bob.tec's Avatar
that sucks man but im pretty sure the 08 ex/lx both come with the r18 ..auto an std. dont make a diff. on the engine so you should be good to go with it
Old Dec 17, 2010 | 03:56 PM
hondadriver's Avatar
I dont know much about the r18 motors but what about things like vtec and knock sensors, etc? Does the lx r18 motor have vtec??
Because d-series lx and ex's motors are different (same block, but the ex has vtec) . If he puts a lx non vtec r18 motor into his ex, he'll throw a code for the missing vtec solenoid, knock sensor, etc.
Like a said I dont know anything about these motors, just figured I throw this out there.
Old Dec 17, 2010 | 05:43 PM
av911's Avatar
DX to EX are all the same.
Old Dec 18, 2010 | 08:49 AM
JustinG60's Avatar
I second that... Just make sure you dont take the knock sensor off of the block or its ruined
Old Dec 18, 2010 | 09:06 AM
99gsvtec's Avatar
There is not enough information here be more specific model i.e. civic accord yes older generation accords, civics are interchange able most of the time if you have an accord v6 ex then no you cant swap an accord 4cyl, but bee_guz is right depending on what generation car your dealing with there may be a difference's where the tranny meets the block, I'm know about pre 01 engines H series which are diff between SH and base but for the most part all D,B & F series can interchange in origiinal chassis with same family engines. Why dont you just put the correct engine in that way resale value doesnt drop significantly, do your homework before you spend the $
Old Dec 20, 2010 | 08:21 PM
cuonglogan's Avatar
No **** sherlock
Also technically you can put a V6 into a V4 chassis.
Dx, Lx and Ex blocks all the same. Only main difference is the EX's vtec head.
Just buy any r18 block and reused your old parts + ex head on the block to save money. By the way, these engine are pretty cheap.
Old Dec 20, 2010 | 09:25 PM
99gsvtec's Avatar
Originally Posted by cuonglogan
No **** sherlock
I didnt know Honda made v4's lol no **** anything is possible a lot of people swap j series v6 engine into there hatchbacks or other shells, but 94-97 accords the engine bays are different between 4cyl & v6 models even fenders arnt the same not just a drop in proceedure
Old Dec 21, 2010 | 03:23 AM
Ricey McRicerton's Avatar
I've got a Honda V4.
It's in my motorcycle.
Old Dec 26, 2010 | 04:29 PM
99gsvtec's Avatar
Originally Posted by caodan2010
It's in my motorcycle. , what cynlinder are motorcycles?
Motorcyles are either singles, twins,V twins, or inline fours so let me know of. V4 lol
Old Dec 30, 2010 | 08:29 AM
Canuck99's Avatar
V-4 Bike motors .. 1000 Interceptor...500 interceptor...750 interceptor ...750 Magna....vfr 1000.. so many I could go on LOL
To bad about the Blown Motor... swap intake exhaust and flywheel also reseal the rear PCV plate , all the screw in block plugs and the timing cover plate just to save the oil leaks later on
You HAVE to change the drain plug gasket evrey time as well and YES tourque to 29ft/lbs , tourque wrenches are cheap, cheaper than a motor
Old Jan 2, 2011 | 10:21 AM
ken9's Avatar
Could be you didn't tighten the oil properly.. The only thing that came to mind..
Old Jan 13, 2011 | 01:38 PM
eeffis's Avatar
WOwza, no plug, crazy.
devin0606
Mar 21, 2017 12:45 PM
205gti
K Series
Dec 11, 2016 11:54 AM
Shazzy04
Jul 29, 2009 07:22 PM
c3p3r
Jan 8, 2003 04:55 PM
