Radiator support
Old Dec 11, 2010 | 03:14 PM
hectic947's Avatar
Icon6 Radiator support
Hey guys. I have a 1996 accord ex vtec. long story short, I feel into a ditch the other day and caused the lower part of my radiator support to cave in a bit. Nothing else was touched, the radiator support was the only thing that took the hit. The condenser and radiator got bent back a bit but nothing major.
So I've been doing some research and I see that the support its spot weld on the frame with a few bolts. I would like to know if its possible to just bolt it on also? Because I don't have a welding machine, and I'm in no financial position to take it to a body shop.
Old Dec 11, 2010 | 08:07 PM
sgraham01's Avatar
Default Re: Radiator support
it's completely spot welded and you will have to drill them out and weld in a new one. if it's not that bad, you can push/pull it back into position. If you don't have body working experience nor a welder, don't attempt replacing it.
Old Dec 12, 2010 | 01:43 PM
hectic947's Avatar
Yeah I kinda figured that. I just thought drilling holes threw the support to frame then bolting it would do the same as welding it. I'll be of work the next 3 days so I'll try to bend it back.
Old Dec 12, 2010 | 02:59 PM
sgraham01's Avatar
it could technically be bolted in, but there may be places such as under the fenders that a bolt head may be in the way. you also don't ever want it getting loose or moving.
Boostn B20
Aug 21, 2008 02:27 PM
dubsolo
Welding / Fabrication
10
Feb 17, 2008 06:50 AM
drunknmunkypow
Aug 10, 2003 07:40 AM
B18CYAAA
Jul 14, 2003 03:22 PM
