Coolant leak
Old Dec 11, 2010 | 03:14 PM
BLU CIVIC's Avatar
Track Advocate
Default Coolant leak
alright, here's the problem. coolant is leaking from somewhere on the back of the engine. sitting at idle, nothing. go for a drive and park it, pours out then stops. cannot pinpoint where the leak is coming from. any ideals? we're thinking maybe the water neck.
Old Dec 11, 2010 | 03:54 PM
gringo7718's Avatar
Default Re: Coolant leak
As the coolant heats up, pressure builds in the cooling system. This is normal btw. Use a mirror and flashlight to help look back there, or jack it up and look from underneath the car if that works.
1. clean off the area as best as you can. (It will be easier to see where its leaking)
2. Warm up or Drive car until coolant starts leaking.
3. Pull over and look at where it is leaking.
4. fix it
mechanics have a tool to pressurize the coolant system so they can see the leak while the car is cold. It makes it easier because everything is not scalding hot.
Old Dec 11, 2010 | 05:55 PM
BLU CIVIC's Avatar
Track Advocate
4. fix it
you talking about that pump that they put on the radiator cap? wonder if there's something similar i can rent from autozone
Old Dec 11, 2010 | 05:58 PM
BarcodeCRXSI's Avatar
If it's coming from the back of the motor, I am assuming that is between the motor and the firewall.
If I am right, then I am going to think that it might be your thermostat? Maybe there's a crack or a crack in the hose?
I'm not too sure.
Old Dec 11, 2010 | 06:07 PM
BLU CIVIC's Avatar
Track Advocate
we replaced the thermostat and checked that hose. if you're standing in front of the car, it's coming from the left side. i'll be trouble shooting it this week
Old Dec 11, 2010 | 06:11 PM
Hmm Maybe the head gasket?
Old Dec 11, 2010 | 06:18 PM
BLU CIVIC's Avatar
Track Advocate
doubtful. the guy i bought it from had 0 problems with it. i even drove the car. had it tuned on the dyno and had 0 problems. now water pours out like a faucet, then stops after a couple minutes and nothing leaks at idle.
Old Dec 11, 2010 | 08:03 PM
Nooch's Avatar
there's a coolnant hose that goes somewhere around the left side slightly lower than the intake manifold. tiny hose. check somewhere around there... that's where mine is.. I'm too lazy to fix it and i have no real problems because of it other than my coolnant leaking completely once a month lolz. i'll fix it eventually.
Old Dec 11, 2010 | 10:32 PM
gringo7718's Avatar
yes sir
Old Dec 12, 2010 | 07:42 AM
d15b7inEF's Avatar
There are i believe 4 or 5 different spots that the leak could be coming from as far a hoses. I know i blew a hose on the right side of the intake. But yours is on the left side and there are three hoses that are right next to each other on the block that all pump coolant in or out. Any of these could be blown and then you also I believe have two hoses on the intake that come from the block. When one blows its really hard to see because it might just be a crack in one of the hoses. Just check all of these very well for cracks or splits.
Old Dec 12, 2010 | 08:31 AM
josephcmiller2's Avatar
I've blown out that U-shaped hose from the intake manifold to the engine multiple times. It usually only leaked after driving it good and then would spray the underside of the hood.
I'll tell you something I've done to find coolant leaks that you should NOT do. I've topped off my coolant system, then disconnected my fan, then waiting for my car to overheat at idle. Then the system builds up pressure and sprays out everywhere. This is dumb and if you let your temp needle get more than just barely past the middle and don't find it, you should quit and plug your fan back in. Do NOT drive it or put a load on it when it's hot.
Old Dec 12, 2010 | 04:12 PM
BLU CIVIC's Avatar
Track Advocate
found the problem. was a nipple on the back that was too big and not tight enough. so replaced it and no more leaks. thanks for all the help
juevi
14
Aug 21, 2011 01:34 PM
Ayashifx55
Dec 23, 2010 10:01 PM
EvenStar
Feb 5, 2007 11:23 AM
732xghost
Dec 22, 2006 07:22 AM
Incognito
Nov 19, 2001 03:39 AM
