Classic Hondas All Pre-1988 Hondas.
Tips on starting the civic after a few years of sitting?
Old Dec 11, 2010 | 10:57 AM
RuskeR's Avatar
Default Tips on starting the civic after a few years of sitting?
I plan to get the 83 running again soon. I'll change the oil, filter, fuel filter etc before starting, but what else should I check or change before I attempt to fire it up?
I'm sure the fuel is worthless. It's been in the garage for 2+ years, and then outside for the last 3 years+. Can you drain the fuel easily in these cars, or do you need to drop the tank?
Old Dec 11, 2010 | 11:37 AM
ken9's Avatar
Default Re: Tips on starting the civic after a few years of sitting?
Might want to check tires pressure and brakes. Dropping the gas tank need more work but might be work checking to see if the tank inside o.kk..
Old Dec 11, 2010 | 01:30 PM
RuskeR's Avatar
I'll be more surprised if the tires are in good shape. They were basically new the last time I parked the car, but this much sitting can't be good for them. I did move the car a few ft forward and back once and awhile, but not nearly enough that I should have.
Old Dec 11, 2010 | 04:55 PM
RuskeR's Avatar
Anyone with a second gen know how easy it is to drain the tank? Unfortunately, the car isn't at my own house so I can't check. Just want to make sure I know when I'm getting into when I head over there to work on it.
Old Dec 11, 2010 | 06:46 PM
ShortyzKustomz's Avatar
Do you know how much gas is in it? I havent dealt with a sitting Honda, but my old Camaro sat for over 5 years, Got it running on the old gas and and added premium to it until I burnt it all out, then changed fuel filter and never had an issue
Old Dec 14, 2010 | 01:40 PM
RuskeR's Avatar
It shouldn't be much.
I guess I could change the fuel filter, and add premium along with some Heet.
Old Dec 15, 2010 | 04:42 PM
cbstd's Avatar
Pull the plugs, squirt some light oil in to the cylinders and turn the engine over by hand before you you fire it up.
Old Dec 21, 2010 | 02:15 PM
antihero12's Avatar
might also wanna check the carbs u know make sure there not all clogged up or gummed up
Old Dec 24, 2010 | 09:05 AM
CountDracura's Avatar
May want to take a second to check fluid levels across the board as well. Also, inspect the battery.
phenomB16
Jul 5, 2013 08:18 AM
kaddi88
Jul 16, 2008 11:56 AM
04AccordEX
Jan 23, 2008 06:19 AM
92greensr
Jan 17, 2004 09:53 AM
Wet Nudl
Honda S2000
22
Jul 26, 2002 06:00 PM
