Going to convert to E85
Old Dec 10, 2010 | 10:49 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Going to convert to E85
OH ****!!!! Look what I got....
Whatever could it be?! Maybe my new fuel setup!!??!!!
**** yes!!!
Ktuned fuel rail
AEM Fuel Pressure Regulator
Aeromotive Fuel Filter
20ft braided line
And this is how it will be setup. I'm going to attach the FPR to the end of the rail.
Old Dec 10, 2010 | 10:50 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Going to convert to E85
*RESERVED*
As I start to instal these for my conversion I will upload pictures. But I wont be starting this till I'm done modifying my supercharger
Old Dec 10, 2010 | 11:39 AM
SolAssassin's Avatar
Hope you don't mind me asking (and this isn't a slam or anything), but why are you converting to E85?
Old Dec 10, 2010 | 01:17 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
E85 has a higher octane than pump gas. Over 100 and it burns much cooler so it makes great power gains.
Old Dec 10, 2010 | 05:05 PM
DaveSi677's Avatar
Some one is looking for some extra power???? Nice I can't to see the build!!!
Btw I asked about what you PMed me and I'm just waiting for a response!
Old Dec 11, 2010 | 06:30 AM
turboteg2nv's Avatar
If you want more power just sell the JRSC and get a turbo.
Looking forward to the install pics though.
Oh PS you might want to take down the first pic showing your address so people won't come steal your car.
Old Dec 11, 2010 | 08:29 AM
Mechanic's Avatar
I believe you are confusing octane (resistance to burning) with power per unit. You are correct that E85 burns much cooler than gasoline, but it is much less efficient as a fuel. It produces anywhere from 12% to 25% less power per unit of volume. (Google is your friend here.)
Old Dec 13, 2010 | 05:35 AM
Needed a reason to use this smiley:
Old Dec 13, 2010 | 06:03 AM
nahonda04's Avatar
Surje.motorsports
this switch can be done a lot cheaper than what zach is doing if anyone had questions about that....
Old Dec 13, 2010 | 08:05 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
You are correct and I apologize. I did some google searching and read more about it. They even had a comment about false believe of octane conversions to being 105.
But either way all my boosted buddies gain HUGE power from this so I'm excited. lol
Old Dec 13, 2010 | 08:26 AM
nahonda04's Avatar
Surje.motorsports
prepare for shitty or shall i say shittier gas mileage...lol...i hope they have e70 out by you too
Old Dec 24, 2010 | 11:55 PM
apexi_rsx's Avatar
dont you need to run bigger injectors to flow more to make the same power as u did on regular pump gas? i see people do this to squeeze alil more power out but i wouldn't recommend doing this on your daily because u will get half the gas mileage as you did before on pump gas for the same power your making now. good luck on the re tune i hope it all works out as planned.
Old Dec 25, 2010 | 06:24 AM
nahonda04's Avatar
Surje.motorsports
yes you do need to run bigger injectors
Old Dec 25, 2010 | 08:23 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
on pump with my 440 cc injectors i was at 50% duty cycle, switched to E85 and I'm up to 75%
Old Dec 25, 2010 | 02:31 PM
nahonda04's Avatar
Surje.motorsports
are you stock?
jw cuz i had mods and stock modded 310cc to 510 injectors and had to go up to id725's cuz i maxed the 510's and i was still at 80% duty cycle
Old Dec 28, 2010 | 04:16 PM
81.5 b series block with 12:0 c/r and crower stage 3's
Old Dec 29, 2010 | 08:15 AM
nahonda04's Avatar
Surje.motorsports
ok that makes more sense because the b-series fuel system has a return where as k-series are return-less therefore making it harder for us to run stock injectors
Old Dec 29, 2010 | 11:49 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Hope this car isnt your daily. E85 is extemely hard/to impossible to start in cold weather. And Im predicting some cold weather where youre at.
Old Dec 30, 2010 | 10:08 PM
josh's ep3's Avatar
Function > Form
I've contemplated making the conversion myself when I was getting everything together for my SC set up but there just isn't many gas stations in my area that have E85. I can't wait to see your numbers after it's all complete!!
Old Jan 3, 2011 | 11:10 AM
1GR8EP3's Avatar
I have heard the same thing, matter of fact I spoke to guy who was running e85 and he said that he would have to let it warm up for like ten minutes before he drove it.
When boosted I see more pros then cons.
Old Jan 3, 2011 | 10:17 PM
nahonda04's Avatar
Surje.motorsports
most places that have e85 also have e70, which is meant to be used in the colder weather...if you do run e85 in the winter, cold starts will be there, the e70 is suppose to eliminate or reduce the amount of time your car takes to start and warm up
Old May 19, 2013 | 05:24 PM
amtheiceman's Avatar
So 2 years later what ever happen? did u ever get it converted?
Flexin5
May 30, 2007 06:01 PM
q8delsol
May 2, 2007 02:17 PM
sleepyhatch00
Sep 23, 2005 12:19 PM
Slowdriver
May 28, 2004 05:41 AM
Big Dick Bandit
Oct 5, 2003 04:29 PM
