Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts
Old Sep 22, 2002 | 10:19 PM
jdmDXrex's Avatar
Default Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts
hey guys just wondering how all of you are running your lsvtecs and gsr's in your CRX's. i have noticed that my distributor and valve cover hit the hood a lot jus wondering if this is happening to everybody else and if all of you have cut out the supports in your hoods or any other methods that you use to create more clearance. any help would be appreciated. thanks
Old Sep 22, 2002 | 10:21 PM
spettinger's Avatar
Default Re: Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts (jdm88crx)
one friend has a C5 in a 91 hatch, another, LS/VTEC in a 91 CRX, just let it rub and bend the hood. haha. i would consider cutting out the braces in a small spot for clearance..
Old Sep 22, 2002 | 10:48 PM
xtrafastcivic's Avatar
Default Re: Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts (wreckedhatch)
my gsr motor doesn't hit the hood..
i'm using a hcp kit..
to my knowledge they are the same angles as hasport...
Old Sep 22, 2002 | 10:57 PM
spettinger's Avatar
Default Re: Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts (XtraFastCRX)
my HCP kit looks like it drops the motor pretty low as well. i don't have hood issues, it seems like i have motor-flops-around-getting-out of first ISSUES. seems noisy and chatters like it is trying to come loose, have you noticed it??
Old Sep 23, 2002 | 01:28 AM
REX VT's Avatar
With a SiR hood you can stuff a B20 in
Old Sep 23, 2002 | 01:48 AM
make sure nothing rubs when the motor rocks...
i use foam...
my car chatters but it's my 4 puck clutch ...
Old Sep 23, 2002 | 04:40 AM
CrxSi10's Avatar
I have a b18c in my 91 crx si and using the billet mounts by hasport. Eventhough the hood supports were cut, the hood still hits the edge of the valve cover by the crank shaft bolt. As of now, the hood is rubbing off the paint on the valve cover and it's almost to the bare metal. Do you guys think oem carbon fiber hood will clear the motor?
Old Sep 23, 2002 | 05:01 AM
SuperCivic's Avatar
Default Re: Hood clearanceof CRX's with GSR block and B16A head with Hasport mounts (CrxSi10)
guys, try adjusting your hood heights. i have a b20 in my EF..using old hasport mounts and STOCK hood. it rubbed at first, but i unscrewed the rubber bump stops all most all the way, and most important, i unscrewed the hood latch at the spring...this provided the necessary clearance..no rubbing!
Old Sep 23, 2002 | 09:09 AM
jdmDXrex's Avatar
thanks guys!
94CoupeNY
17
Jan 25, 2013 05:14 PM
Charlie Moua
13
Mar 1, 2011 05:22 PM
Dkahn18
Jan 19, 2010 05:10 AM
freedm
18
Jan 14, 2009 07:08 PM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
