co2 drawing
Old Dec 9, 2010 | 12:02 PM
edsperformance's Avatar
Default co2 drawing
I need help,can some one put a drawing to how exactly
install a co2 lines for control the boost i only use
one solenoid, thanks for your help
Old Dec 9, 2010 | 12:40 PM
Mo_Spec's Avatar
Default Re: co2 drawing
please ignore my inability to draw and post pdf lol
this is how it is run on our car, using a hondata solenoid. Port 3 is actually on the other side i just drew it for reference.
Old Dec 9, 2010 | 12:50 PM
thanks,for me is what i need,so if i want to run 40psi
i need to put the regulator of the co2 in 40 or
im wrong,let me how its work
Old Dec 9, 2010 | 12:52 PM
were cant i found the small bottle with the bracket
for the roll cage,thanks
Old Dec 9, 2010 | 01:00 PM
Mo_Spec's Avatar
the regulator psi depends on your set up, spring pressure etc.. most start at 60 and see what kind of boost that yields.
this is good kit to get you started
http://www.summitracing.com/parts/DED-AB-10K/
Old Dec 9, 2010 | 03:09 PM
SPOOLINmatt's Avatar
the solenoid connections look backward.
Old Dec 9, 2010 | 03:20 PM
Mo_Spec's Avatar
Yep your right...... Swap 1 and 2.
My bad
rudebwoy
Jun 5, 2018 06:30 PM
Kid-jdm-teggy
Feb 25, 2014 02:24 PM
b18s372
Jan 26, 2011 09:11 AM
Spunkster
Feb 6, 2007 04:28 PM
Duck Sauce
Aug 10, 2002 08:00 PM
