how do C02 boost controller set ups work?
Old Jan 22, 2011 | 04:16 AM
b18s372's Avatar
Default how do C02 boost controller set ups work?
just wondering?
Old Jan 22, 2011 | 04:18 AM
TDautowerkes's Avatar
Default Re: how do C02 boost controller set ups work?
Instead of relying on manifold pressure to close the gate, you use the co2
Old Jan 22, 2011 | 08:17 PM
b18s372's Avatar
i saw on some cars the co2 tank hasd an air regulator. what psi are they feeding the solenoids?
Old Jan 23, 2011 | 04:06 AM
Zer0_SpeedWorks's Avatar
yes also most use NLR to control it with co2
Old Jan 23, 2011 | 08:57 AM
Mo_Spec's Avatar
We regulate ours at 60psi
Old Jan 23, 2011 | 04:57 PM
an NLR is NOT required to run co2!
We run our Ek with just a solenoid and CO2!
Blown90hatcH's Avatar
werd
Old Jan 23, 2011 | 07:17 PM
legomytego's Avatar
what are the benefits of using it ? just more reliable ?
Old Jan 23, 2011 | 07:21 PM
runsfromdacops's Avatar
more control. and it lets you run a soft wg spring and still make 40+ psi
Old Jan 23, 2011 | 08:07 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
you can do the same by running one solenoid on the bottom of the gate and one to the top. Then you dont have to fill that thing up
Old Jan 23, 2011 | 08:52 PM
I agree, thats why I said most...
Old Jan 24, 2011 | 05:35 AM
Old Jan 24, 2011 | 08:26 AM
b18s372's Avatar
what do you use to control 2 solenoids
Old Jan 24, 2011 | 09:41 AM
tepid1's Avatar
A good ECU.
Run one standard and run the other off a seperate table. When you need more boost pressure the second one comes into play.
Old Jan 24, 2011 | 09:44 AM
061000rr's Avatar
Originally Posted by tepid1
A good ECU.
can this ^ be done with aem?
Old Jan 24, 2011 | 03:15 PM
edsperformance's Avatar
can some one please put a layout with the co2 bottle to the waste gate using
one solenoid,thanks
Old Jan 24, 2011 | 05:21 PM
tepid1's Avatar
I think it can be done with V1 and V2. Not 100% positive though
Old Jan 24, 2011 | 07:04 PM
vtekthis's Avatar
yes, as long as you have 2 available pulse width outputs.
or you can just use c02 if u dont have avail pwm's
Old Jan 25, 2011 | 02:10 AM
Everton Et's Avatar
I use the controller Fueltech
http://www.fueltechusa.com/br/produc..._dual_solenoid
FuelTech's BoostController is a multi-stage equipment which precisely manages up to 6 stages of boost and an extra launch stage, allowing the eficient and precise traction control for cars and motorbikes. It works controlling the top end wastegate pressure an it's possible to determine a dual ramp turbo pressure growth to set a smoothly turbo load at shifting, turning the engine's power generation ideal for the traction levels.
To work with high boost levels in racing applications, the BoostController is able to work together with a CO2 reservoir, keeping the appropriate pressure and traction controls.
Functions:
- Wastegate's Top End Boost Controller
- 6 Stages of Boost and 1 Launch Stage
- Sequential and Circuit Modes
- Boost+ and Boost- keys to instantly boost increase or decrease
- Dual Ramp Boost Growth Control per Stage
- Dual Pressure Control Solenoids Switch
- Wastegate Boost Control by pressurization or by CO2 reservoir for quick and precise response
- 87psi Integrated Pressure Sensor with 0,145psi resolution
- No computer required for operation
Old Jan 25, 2011 | 02:29 AM
tepid1's Avatar
^^ That is just like using an NLR AMS-1000
Old Jan 25, 2011 | 05:46 AM
b18s372's Avatar
one solenoid,thanks
x2
Old Jan 26, 2011 | 09:11 AM
Mo_Spec's Avatar
here you go, another thread on this co2 stuff. read the whole thread cause the drawing i did has the ports marked incorrectly.
https://honda-tech.com/forums/drag-racing-36/co2-drawing-2871777/
FastechAccord
Nov 17, 2017 02:28 AM
Pumpking.
Feb 3, 2012 10:31 AM
bads2k
Aug 20, 2011 09:53 PM
edsperformance
Aug 5, 2011 07:33 PM
LOGONZOJLS
Dec 22, 2006 11:25 AM
