Backpurging
Old Dec 8, 2010 | 02:41 PM
b16bri's Avatar
Default Backpurging
I've searched on here/ google and didn't find anything. I think I have a basic idea of what backpurging is but i'm sure i'm missing a bit. my question is when is it necessary ? Mig welding tig welding ? Aluminum, stainless, is it used on exhausts or just manifolds. I'm a complete noob with welding trying to learn so please be gentle lol
Correct me if i'm wrong Backpurging is when you have a extra line comming from your tanks pumping shielding gas inside the peice being welded to make sure you get good penatration all the way therew so no sugaring occurs.
Old Dec 8, 2010 | 03:11 PM
5thgen's Avatar
Default Re: Backpurging
Almost always encouraged on stainless.
Here you can see where gas shielded the inside, and where it did not.
I've never backpurged on aluminum....from what I've read it isn't really needed. I would like to try it sometime and see if anything different happens on the inside.
Old Dec 8, 2010 | 07:03 PM
scikotictc232's Avatar
any pictures of peoples back purge set ups ?
Old Dec 8, 2010 | 07:36 PM
b16bri's Avatar
Ok so weather you mig or tig it if your doing SS it's necessary. Anything else ? Also dose anyone have any pics of there set-ups or can they explane in detail how this is done
Old Dec 8, 2010 | 09:12 PM
5.0 Killa's Avatar
It's nothing fancy usually. I've seen high end aerospace parts being welded and back purged with nothing more than an extra tank, regulator and a hose.
Old Dec 11, 2010 | 07:55 AM
EF9_TryMe's Avatar
Sorry for the noob reply, but what is SS ?
Old Dec 11, 2010 | 08:07 AM
sc34dc4's Avatar
'S' tainless 'S' teel
Old Dec 11, 2010 | 04:18 PM
ManBearPig4silly's Avatar
It's not always neccesary to purge if you are mig welding stainless.
Old Dec 13, 2010 | 11:57 AM
Agtronic's Avatar
Technically, you should back purge whenever you are going to bring stainless steel to melting point, where its surface will oxidize if exposed to oxygen. If you don't purge the inside of a pipe, you will get a big grey surface that has a crystal-like appearance.
The main idea with purging is that you are purging all oxygen from the inside of the pipe, using an inert gas. In theory, you could acheive the same thing using a vacuum inside the tube, but this would suck in your weld pool. If you were to weld in a vacuum chamber with equal pressure above and under the weld, it would work too. What is important to understand is that the argon is not "actively" doing anything to the metal, it is just forcing out all ambient air from inside the tube. You could use any inert gas you like.
Now, if you were welding critical parts for the aeronautical industry, you would obviously purge absolutely everything, always.
But in the car industry, it's really up to you, and what you feel comfortable with. I personally only purge critical parts such as exhaust manifolds and downpipes. Parts that will be subject to a lot of heat and a lot of vibration.
I do not purge stainless boost pipes, or exhaust systems. For boost pipes, I fusion weld and am careful to make sure to not penetrate the material, to keep the insides of the tube clean. On exhausts, I use filler rod and. This is what has worked for me. I have never had a single boost pipe or exhaust system crack. Ever.
As for a setup. Ideally, you want a second regulator so you can know how much flow is going into the pipe. You also want to avoid a T fitting post-regulator, as your flow is being divided and you can't know how much is going to each end.
Here are some pics of my setup.
Dual regulator :
Table-mounted valve to shut off gas flow when stopping for tungsten prep, phone call, etc ...
Purging in action:
And this is how it should look inside after you're done welding:
Hope that helps!
Old Dec 13, 2010 | 12:58 PM
92cxturbo's Avatar
Hope that helps!
thats some good info! what do you mean by boost pipes? Are you talking about intercooler piping?
Old Dec 13, 2010 | 02:32 PM
TinyT's Avatar
^^yes he is
Old Dec 13, 2010 | 07:12 PM
Agtronic's Avatar
Yep, I was referring to intercooler piping. I normally fusion weld it when using stainless.
Old Dec 13, 2010 | 07:13 PM
9bells's Avatar
OG Fabricator
I'm sorry, but that is just plain sexy!!!
Old Dec 14, 2010 | 06:40 AM
Agtronic's Avatar
Thanks man!!
Old Dec 15, 2010 | 06:34 AM
ToxicFabrication's Avatar
OG Fabricator
Dual regulator :
Purging in action:
Hope that helps!
Show off
As always agtronic looks awesome and great help to the noobs!
Old Dec 15, 2010 | 06:40 AM
champLSinteg's Avatar
Originally Posted by ToxicFabrication
Show off
Where have you been? I dont see you in here anymore. Post some more work!
Old Dec 15, 2010 | 07:35 AM
onefstek's Avatar
I weld mostly 16ga and 18ga so my set up is pretty simple. I have a separate bottle with a regulator, the hose with a rubber cap that fits in the tubing and another cap at the other end. Found out the hard way that you want to have a little pin hole in one end, otherwise you end up pressurizing the system when you do your last weld.
Stefan
Old Dec 15, 2010 | 09:09 AM
92cxturbo's Avatar
what cfh are you guys setting your regulator to on your extra/backpurging bottle?
Old Dec 15, 2010 | 09:41 AM
onefstek's Avatar
^^^ I run mine really low, about 5cfh or even lower, depends what im doing.
I can build about 3-5 headers before I run the bottle down. Its a small bottle btw.
Stefan
Old Dec 17, 2010 | 07:00 AM
92cxturbo's Avatar
Stefan
I was thinking about getting an extra small bottle just for backpurging, but I didnt know if I would be going through those to fast. I think I'll be fine though. Thanks for the info everyone, This is my new favorite section on ht!
Old Dec 17, 2010 | 05:50 PM
b16bri's Avatar
OneFstek-... why do you need a pin hole ? If you dont what will happen ?
Agtronic- Thanks a lot for all your info it was helpful. I'm a noob to welding learning on my own. What the difference in useing filler rod vs fusion weld. what is the difference in the two. Sorry if i sound stupid dont mean to lol Trying to learn. PS thoes welds do look amazing.
Old Dec 17, 2010 | 07:05 PM
9bells's Avatar
OG Fabricator
Stefan means that on your last weld you will have a sealed system, and the pressure from the bottle will try to escape through your weld since it is the weakest thing in the system when it's molten. This is why I never try to seal the system perfectly. Stainless or brass wool is excellent for purging for this very reason. Even balled-up tinfoil like Markku uses is great too.
Old Dec 17, 2010 | 09:55 PM
5.0 Killa's Avatar
I just picked up a 2nd regulator for peanuts to use for my back purge setup. I'm going to use that remote shutoff idea, thanks Agtronic.
Old Dec 18, 2010 | 03:36 PM
atutt's Avatar
Just curious if anyone back purges their aluminum work? I recall seeing this once.
Old Dec 18, 2010 | 04:15 PM
9bells's Avatar
OG Fabricator
It doesn't make any useful difference. The backside oxide doesn't see the same conditions as the front, so it always looks funky. OAW is the only one to make a pretty bead on butt joints.
