Ok, I have 2 S-AFC/boost questions. Thanks
Old Sep 22, 2002 | 08:44 PM
freeplay's Avatar
Default Ok, I have 2 S-AFC/boost questions. Thanks
All right, I hooked my S-AFC up for monitoring purposes (no boost yet), and I cut the pressure wire and hooked it into the S-AFC and everything, and I started my car, and it idled really wierd. It would jump around, and when I tapped the gas pedal, the RPM's would instantly drop, then go up. Kinda weird. Is this normal?
Second Question:
People are telling me to set my S-AFC at -30% across the board when I get my 450cc injectors and 6psi of boost. But my understanding was that at different RPM's, the setting would be different. So, is the -30% good all the way across, or are there any better ideas? Thanks for anyone who helps.
Old Sep 22, 2002 | 09:13 PM
inspyral's Avatar
Default Re: Ok, I have 2 S-AFC/boost questions. Thanks (WannabeTurbo)
Are you sure you made the the correct car-type and sensor-type settings on the AFC before you started the car?
Old Sep 22, 2002 | 11:45 PM
riceboy's Avatar
What motor and ECU?
Old Sep 23, 2002 | 05:37 AM
senpai's Avatar
I think someone installed/configured their SAFC wrong...
Yellb16crxsi
Sep 6, 2004 11:06 AM
Goldfingiz
Jul 22, 2003 12:06 PM
joeski
May 8, 2003 12:09 PM
freeplay
Sep 18, 2002 09:42 PM
