90 CRX HF 1st gen b16a
I've been trying to figure this out but to no avail. My battery is good. Starter is good. I turn the key and I can hear the fuel pump priming but when I turn to start no click or anything from the starter. I already replaced the plactic on the clutch pedal. Could it be the starter relay? If so where is it located? And where could I buy one?
check your grounds if your not getting anything its probably the grounds. a little more info also did you just do the swap and put the engine in the car? have you check all grounds, all fuses?
Checked starter at two different places, good
Checked main relay and ignition relay good
Battery good
Bypassed clutch safety switch
All grouds are good.
Did I miss something?
I turn my key and all my lights come on but when I turn to start no click no sounds from the starter whatsoever.. my fuel pump primes. I can push start the car but that's getting old quick. Any ideas?
Battery good
unplug small push on wire at starter, hook test light to it and turn ignition switch. does the test light light up? if not bad ignition switch or brake in the wire from switch to starter
turn your ign. on , take a jumper cable from the pos. battery and hold it on the starter pos. for 2-3 seconds if starter does engage your problem is between the starter and the ignition. if doesn't engage then bad starter
check your ground cable that goes from negative on battery to the top of the trans. ive had that issue before. the bracket wasnt getting a good connection. orr the ground cable could be broken
Check if the ignition cylinder is sending voltage to the starter solenoid, the small wire going to the starter. When the key is held in "Crank" position, you should see voltage at this wire, which operates the starter solenoid. If you do not see voltage at the starter, test the wires on the ignition harness (Black/White) and test for 12V + output when key is held in starter position.
How to check starter.
http://www.youtube.com/watch?v=JIlwKOXmTFU
http://www.youtube.com/watch?v=TNiYZUfN3oA
Thanks gringo.
I can jump the starter from the battery to the starter solenoid directly. Tim not getting any voltahat's how I'm starting it at the moment. I'm not getting any power on the cable to the starter solenoid I'll check those black and white wires first thing in the morning
Thanks gringo.
wambus
Feb 12, 2004 03:09 PM
