Which engine would be the easiest to put in as a replacement for my F23A4?
Hi guys,
It feels like my F23A4 doesn't have long to last, so I'm doing some research into which engine I could put in as a replacement without having to modify anything else. The car is a 2000 Honda Accord Coupe. I would prefer to swap only the engine and leave my current ECU alone. Thanks!
You can use H22/23's or F20B if you wanted to also. They are a straight drop in. You are going to have to change your ECU though.
Thank you for your response! So if I were to buy an H22A5 engine, would I have to buy it with a gearbox? Or would I be able to use my old gearbox from the F23A4?
The F23 gear box will bolt up, but it probably won't be the best option for getting the best performance or economy out of the H22.
There are a few things that need to be swapped for a 6th gen Accord H22 swap. Here is an older link for a 6th gen H22 swap.
https://honda-tech.com/forums/honda-accord-1990-2002-2/6th-gen-h22-swap-info-473019/
Also I'm not sure what the immobilizers are like over seas but the only H22 ECU that doesn't have an immobilizer installed here in North America is the 96 Prelude Si VTEC.
You will also require an H22 exhaust manifold/header......... Obvious bolt-on mod anyway.
However, If you don't want to swap ECUs, I would suggest dropping in another F23.
Cheers
Cheers
If its just a quick replacement and you want to do a transmission swap down the road or just daily driving it, then its fine.
But if you want a faster 1/4, everytime you are shifting your going to be out of VTEC.
Even the H22 transmission is consider quite long if you are comparing it to a B16/ITR.
You also can get a P28 ecu and chip it using hondata and have it run on the correct basemap.
https://honda-tech.com/forums/showthread.php?t=473019
Cheers
Cheers
Honestly I've never worked on a ULEV motor. I'm not 100% on what the differences are other than the O2 and the tuning of the ECU. If you take the wideband O2 and any other ULEV related sensors/parts and swap them over to the F23A1 it should work.
I know the exhaust manifold is different for the ULEV model as well (pretty sure because of the wideband o2 sensor). That's the only other thing I can add to GhostAccord's post.
But what about the ECU? Say, I get a new F23A1 (non-ULEV) engine with an exhaust manifold, swap it into my car, plug my old wideband O2 sensor in it and hook the whole thing up to my old ULEV ECU. Will it throw any CELs? Or should I get a new non-ULEV ECU to be on the safe side?
So give it a shot, unless you can find a F23a1 ECU for cheap, then might as well get that and save yourself some hassle.
Just a note, using a F series tranny with a H series motor, will reduce performance, but increase fuel economy. Lower RPMs on the freeway translates to less driveline losses, and therefore more efficient travel.
