Honda/Acura oil pan stud kit (replaces bolts) SALE.
I have a stud kit that replaces the oil pan bolts on all Honda/Acura engines. This stud kit replaces the OEM bolts that have a history of stripping or cross-threading the threads in the aluminum blocks of Honda/Acura engines, among others.
Details:
-Studs and serrated lock nuts are made of hardened steel.
-Studs have an allen key in the end to make installation simple.
-Once kit is installed, one no longer needs to worry about stripping bolt holes in their aluminum block.
-Lock nuts are flanged, making it unnecessary to use a separate washer.
-All components meet or exceed OEM specifications.
-Kit provides more uniform pressure on oil pan seal.
-Studs make installation oil pan easier.
-Studs are your choice of M6 x 1.0 x 35mm or 50mm and class 12.9. 35mm is the standard OEM bolt replacement length. 50mm is an extended length option.
PM me if you have any questions. $21.95 plus shipping
Details:
Fred Dukes
Apr 29, 2017 02:48 PM
