Idle issues.
So I have just swapped a d16z6 into my 88 wagon. the motor is mpfi and obd1.
Right now It idles at 2500rpms at all time(hot and cold)? there are no codes.
I took the IVAC cylinder off and put my friends on (from another d16z6) and it didn't change a thing.
The car's timing is spot on also.
Does anyone know specifically what may be causing this? if its a vacuum leak. is there a certain line in particular I should be checking?
Thanks so much to anybody that can help me!!
mine just started acting up in the same way.i found that the red wire on the tps needs attention.try wiggleing the wires a lil when its running and see if theres a change.i also just found out that my tb gasket had a leak the whole time.things to consider
chargerbandit
May 26, 2018 12:32 PM
92cb7sk8er
Mar 25, 2011 08:25 AM
