JDM SIRII B16a swap OBD2 motor tranny(LSD) ecu - $2800
I’ve got a JDM SIRII B16a engine swap for sale.. I got the swap last Christmas and drove on it for a year. I put less than 10K miles on it and it came from Hmotorsonline. It has had all the tune up items done on it less than 10K ago. NGK Plugs, NGK wires, OEM rotor, OEM cap, timing belt, water pump, rear main seal, vtec sol gasket. It has an OEM replacement Exedy clutch in it and a fidanza 7.5lb flywheel. Trans has factory LSD. NO HARNESS. Has a P2P intake manifold gasket. will come with P2T ECU OBD2a (96-98)
