d16a6 oil control jet O ring question
Hi guys,
I'm doing the head gasket on my crx and my haynes manual Says to replace the oil control jet o ring. But at the dealer I was told it doesn't have an oil control jet?
Soo now I'm a bit confused.
Can you guys help me find the part number for it
I don't have the head off yet so I have no clue.
Is it necessary to replace. I've googled pics of newer civics and it looks hard to replace so some tips on how to replace it would be nice.
thanks
thanks
ehh i wouldnt worry about it. ive never replaced it. ive only ripped the whole control jet out to do a mini me swap,(yes it has one) and i used a drywall screw threaded into the middle to pull it ouut of the head. not a scewdriver. good way to scratch the block IMO
can't believe you sissys are all paranoid in using a small screwdriver
some people either use a screwdriver or a screw or anything pointed to remove the damn thing...its even recommended in one of the mini-me write ups in the faq's...!!!
http://crx.honda-perf.org/articles/z6swap/z6swap.html
some people either use a screwdriver or a screw or anything pointed to remove the damn thing...its even recommended in one of the mini-me write ups in the faq's...!!!http://crx.honda-perf.org/articles/z6swap/z6swap.html
Thanks guys, I used a toothpick to get mine out, but the o ring goes on the jet not on top right. I couldn't figure it out, I thought it went on top so I just ended up leaving it alone. because it didn't look like I wzas given the right one
The old o-ring is square because it's been in there for years and formed itself to the shape it's been confined to. The o-ring is made of rubber so it does stretch you know...
I thought that , but it's too late now, it was still in good cond. though and everything is working fine so I got lucky
B18C Turbo
Sep 3, 2006 09:42 AM
