Front Pass side Ball joint/ arm
Old Dec 6, 2010 | 07:00 AM
Hondaa99's Avatar
Default Front Pass side Ball joint/ arm
I have a 99 accord.
I noticed a disturbing clunk when turning at highway speed and also going over bumps.
The top ball joint had too much play - It could pull the top of the front passenger side tire out 1/4" on the affected side, but could not do so on the drivers side. This reproduced the clunking.
After reading some prior posts on this forum, I replaced the control arm which includes the ball joint.
It is now approx 1 month later and the problem has re-occurred - in the replaced part.
questions:
Is there something ELSE that could be causing these ball joints to fail?
Is it possible that I just got a bad replacement part? I got the part from AutoZone as suggested here, so I believe it will be covered by warranty. But I want to make sure there is not something else I am overlooking.
Thanks in advance
Old Dec 6, 2010 | 09:02 AM
sgraham01's Avatar
Default Re: Front Pass side Ball joint/ arm
double-check that you have the joint fully tightened and that it's not just the stud moving in the spindle. if the conical bore in the spindle is worn out, you would need a new spindle (used).
Old Dec 6, 2010 | 09:33 AM
Hondaa99's Avatar
I do not believe that the bolt/spindle are the problem.
the play is at the top ie the ball joint itself, not where its connected to the control arm.
I am concerned that there is something that might lead to this failure?
otherwise, I had bad luck with a bad replacement part.
Old Dec 6, 2010 | 10:06 AM
sgraham01's Avatar
disconnect the ball joint and verify that it's loose. get a new part under warranty. i can't think of anything that would be causing a failure that quickly. if you had a wheel/tire problem that is causing a bad enough vibration to wear it out, you'd be feeling it.
geartex
Jan 8, 2018 06:46 AM
dumbidea
Aug 20, 2017 07:52 PM
Kevins89notch
21
Nov 4, 2013 06:17 AM
globy123
Aug 17, 2013 03:10 PM
Big Jack Earl
Jul 6, 2009 10:01 PM
